Sequence for shimming convertible body on a new chassis?
I have had my 69' convertible apart for a few years and it is at the shop having the body moved from the old chassis(bad frame) to a rebuilt chassis. Body is moved now to new chassis. The shop does full restorations, but does not specialize in corvettes. They have my aim, and chassis restoration manual. They want to finish the body work and need to get the body gaps correct etc in order to do that.
Well, since this is a different chassis and someone replaced the solid shims with later rubber mounts we have no idea what number shims are needed where, also I realize it is most likely harder to get convertibles aligned as they are not as rigid. Anyway, is there a rule of thumb or method to be used in the shimming/alignment process? The door of course have been off the car, so they have to be re-aligned also. I thought that for the most part the number 3 and 4 mounts would affect the door gaps the most, right? The adjustment for say the back upper edge of the door where it meets the rear quarter panel can really only be adjusted by adjusting the door, right? Body shims will not help with that, correct? I have no experience with adjusting the body and I am looking for direction here. I assume many of you have done this many times and seen all kinds of weird issues. Thanks, Joe |
Hi Joe,
I believe the usual procedure used for putting a body back on the same chassis should be proper for putting the body on a different chassis also. Remember, in St.Louis when the frame went into the jig to be measured in order to determine the # of shims required at each body mount, the body was on a different line, and the 2 hadn't even been introduced to each other yet. So I'd recommend putting 3 shims on each mount, then set the body in place, and begin to add or remove shims in order to obtain the gaps and panel fit you're looking for. Unless something is tweaked this can often be done with 2, 3, 4, shims at each location, with an occasional 1 or 5. I'd certainly check the fit of the front and rear bumpers too while working on the shim requirements. Good Luck! Regards, Alan |
Originally Posted by jhudec
(Post 1587792909)
Well, since this is a different chassis and someone replaced the solid shims with later rubber mounts we have no idea what number shims are needed where, also I realize it is most likely harder to get convertibles aligned as they are not as rigid. Anyway, is there a rule of thumb or method to be used in the shimming/alignment process? The door of course have been off the car, so they have to be re-aligned also. I thought that for the most part the number 3 and 4 mounts would affect the door gaps the most, right? The adjustment for say the back upper edge of the door where it meets the rear quarter panel can really only be adjusted by adjusting the door, right? Body shims will not help with that, correct? I have no experience with adjusting the body and I am looking for direction here. I assume many of you have done this many times and seen all kinds of weird issues. Thanks, Joe Thanks Your Friend Roger |
when you have an unknown or different setup,
I start with 2 shims in all the inaccessible mount positions. then add shims as needed to the accessible areas, until everything is level/and evenly distributed. good luck |
Originally Posted by 69Vett
(Post 1587796447)
I start with 2 shims in all the inaccessible mount positions. then add shims as needed to the accessible areas, until everything is level/and evenly distributed. good luck Thank You Roger:crazy: |
(Post 1587792909)
Well, since this is a different chassis and someone replaced the solid shims with later rubber mounts we have no idea what number shims are needed where, also I realize it is most likely harder to get convertibles aligned as they are not as rigid. Anyway, is there a rule of thumb or method to be used in the shimming/alignment process? The door of course have been off the car, so they have to be re-aligned also. I thought that for the most part the number 3 and 4 mounts would affect the door gaps the most, right? The adjustment for say the back upper edge of the door where it meets the rear quarter panel can really only be adjusted by adjusting the door, right? Body shims will not help with that, correct? I have no experience with adjusting the body and I am looking for direction here. I assume many of you have done this many times and seen all kinds of weird issues. Thanks, Joe Rogman |
#1 your looking to verify the body sits on the frame level, besure frame is leveled first.
your looking for uniform height all the way around the car, usually checked at wheelwells. your looking to ensure your doors sit in the opening squarely. After everything looks good... my final gauge, is how much weight rests on each mount pad, you want to have app. same weight on each pad. increase or decrease shims as required. This is the height shimming process, Body side-side, and front to back, is a bigger can of worms. good luck... |
