So how good are Lingenfelter ported 113 heads?
http://www.lingenfelter.com/mm5/merc...5#.VB3qHxZBqQA
They're pretty pricey, do they stack up to AFR 195 heads...which are Cheaper? |
what are the numbers advertised by lingenfelter? and how do they compare?
My guess is that they would be as good but you will be paying a little for that name. |
Sounds nice and sure they will run good but Id rather have a brand new set of AFRs. Those are smog legal too;larger valves + lighter valvetrain thicker decksetc
I dont see how the Lingenfelter heads arent smog legal they were when cast? :willy: $300 to remove CNC ridges a waste. |
...do they stack up to AFR 195 heads... |
