1999 c5 1/4 miles times stock
i just bought a corvette and have a few trans am and i have run them but hadt tried to vette yet,wat would you guess a stock 1999 c5 run no mods,2.73 gears on street tires do in the 1/4.and wat would it run with 3.42 gear still all stock.i kw its hard to guess but just trying get idea its sluglish out the hole compared to my trans am but pulls hard from a roll though.i live in nc if that helps with the air pressure and sea level stuff.thanks
Originally Posted by benhildreth1970
(Post 1587875690)
Skip the 3:42's and go with a 3:90. My old car... I started off with a 3500 stall first and added bolt on's. |
[QUOTE=123sugey;1587876069]13.2-4
Skip the 3:42's and go with a 3:90. My old car... I started off with a 3500 stall first and added bolt on's.[/QUOTE i was thinking 3.73 to start with but can find 3.42 easy and cheap and just swap whole rearend.how does the 3500 stall affect driving wise at with the 3.90s like cruising wise.and time you posted is that wat urs done with stock gears are with 3.90s. |
