64 vert with air
I am going to look at a 64 vert with (according to the owner) factory air conditioning. What should I look for to prove it is a factory A/C car? I don't think there is any info on the trim tag? How about the engine code? Lastly, the car is in decent shape,it runs and drives, what would the car be worth? I don't know the HP. Thanks :flag:
Let me jump in with some basics first. The central vent, battery on the drivers side, washer bag on the same side. That will get you into the ball park if it was factory installed. Value is more difficult. Lots of variables. I'll let someone else try that.
Make sure the bird cage is solid. Check for rust in the frame at the kick-up and take the glove box out to check up in there. Think there are either 6 or 8 screws to take out for the glove box. Sure does open up the section of the cage for viewing. Bud. |
I have a 64 Coupe with A/C for sale in the "For Sale" section. A/C cars have a vent over the clock in the center of the dash. Also, the alternator is on the driver's side. Look also for tinted windows.
My coupe has an Air Condition sticker on the back window. Don't know where or if this was affixed on Verts. I would also ask if the car is running R12 (the original refrigerant), or converted to R134. NADA indicates about $3k upcharge for Average Retail. Good luck and if you need more info, shoot me a PM. |
Originally Posted by robbie shirkowski
(Post 1587889582)
In addition to the indicators already provided, check: the driver's side inner fender has an access panel for battery removal the core support does not have X bracing across the opening the right side kick panel vent has no louvers in the top half. The decal would be on the passenger window, lower left corner I believe. Good luck on the hunt! |
Aside from the engine code, all that can be bolted on well after the factory. On the passenger side firewall will be a place to look for the cut out. But, that could be faked too if a full rest was done. However, if original paint on the firewall, I think you can determine originality there.
1 Attachment(s)
(Post 1587889582)
Factory A/C will have a very large steel evaporator case on the engine side of the firewall; aftermarket A/C has everything inside the car, under the dash, with a flat plate on the engine side. A/C Engine codes: 250 manual = RP, 250 Glide = SK, 300 manual = RQ, 300 Glide = SL, 365hp manual = RR (standard ignition), RU with T.I. :thumbs: |
Thanks for all of the replies. i have found out more info on the car. It has factory A/C PS PB automatic. 300 HP. If all checks out I would still like your opinion on value. The 64 is the white elephant of the midyears but it has nice options! The auto is a rare option but hurts the value.
(Post 1587896723)
Enough with all this white elephant stuff about '64's. I try to be respectful on the forum but the fact is that car for car a 64 TENDS to be a bit less expensive- hey, some year had to take the slot- but I feel zero inferiority about owning one. Rather, I feel strongly that "stigma" of a 64 is wayyyyy overblown by a minority of loudmouths in a few circles we all know. I happen to like my '64 aesthetically better than any other year, and 65/66's come next. The general public appreciates all the years, even if they have an easier time "spotting" a SWC. To the OP (to keep this slightly on topic) if you are new to this, don't buy into "white elephant" BS. Buy the car you like, pay what you feel comfortable paying, and drive it!
I meant no disrespect to any corvette owner. A corvette is a corvette!
(Post 1587899719)
Originally Posted by ChattanoogaJSB
(Post 1587898721)
The good news is that those who disparage the '64 serve to bring the price down so that folks who don't buy into the red-headed stepchild or white elephant BS can score a great car at a great price. So there is an upside to all of the silliness. -- Steve |
Originally Posted by Mike Geary
(Post 1587890896)
Yes the engine suffix would indicate a factory A/C car.
In addition to the indicators already provided, check: the driver's side inner fender has an access panel for battery removal the core support does not have X bracing across the opening the right side kick panel vent has no louvers in the top half. The decal would be on the passenger window, lower left corner I believe. Good luck on the hunt! Verne:thumbs: |
2 Attachment(s)
Thanks. It looks like that part is being reproduced.
Verne:thumbs: |
(Post 1587896723)
