A41 4L60E automatic conversion kits are back!
SST is proud to announce the return of the popular Keisler A41 automatic overdrive kits for 1968-1982 Corvette!
Learn more here: http://shiftsst.com/blog/122-automatic Kits for C3 are complete with all necessary components to make the conversion, including fluid. • Better performance • 30% rpm reduction for excellent highway characteristics • Complete kit from converter to driveshaft • No TV cable to fuss with like 700R4 - 2 stand alone controller options available • Reliable • No mods or odd driveline angles like Gear Vendors Call or email today - 844.609.8187 or info@shiftsst.com |
Anyone done a 4-speed to auto using this kit?
Have any of you installed one of these kits to replace a 4-speed? I'm considering doing this conversion in my 73 big block convertible. Being a little disabled I'll have to find a local shop to do the installation. What I'm wondering is if any of you have actually done this conversion, what pit-falls did you encounter and how long did it take. Since I'll be paying to get the job done I'm reluctant to just drop my 73 and a box of kit parts at a shop and give them an open ended contract to start working without some estimate of hoe many mechanic hours I might have to pay for.
Originally Posted by pe73454
(Post 1597803368)
1. Assuming yours was a 4 speed from birth, you'll need to convert to the auto car crossmember bracket configuration to use our crossmember. We have the brackets and having the body off the frame will be a huge help here, if not an outright requirement, since grinding and welding are involved. Or, cut your center section and fabricate your own arrangement from parts we supply. 2. Automatic brake pedal. This would be optional but if you want to make it 100% correct looking it will be needed. 3. Automatic shifter mechanism. I *think* '72-'76 are the same but do your own research. 4. Auto car console panel. These are different between manual and auto cars up to '76. 5. Any wiring for P/N safety switch or other parts specific to the auto cars. This really shouldn't be a big deal for a shop that knows Corvettes. If they don't know Corvettes, I would prefer (personally) to find a place that does. They would also be more likely to have or help find the parts you'll need. |
