Questions about change CAM but do headers later
I just recently got my heads fixed (08Z) with SS exhaust valve,and bronze guide. I do want to do the cam mod since the heads are out. (save some labor money)
But my budget is limited now, so I cant do the long tube headers at the same time, but will do it around Christmas. I know cam will perform better with long tubes, and yes Stock headers and cat will have a larger back pressure, but is it going to hurt the car? or I could do this step by step? maybe a mild tune will be helpful? any suggestions and advice will be appreciated Heads are ported as well as the TB and intake manifold. and has a KN CAI Thanks Frank |
Go for it. It's not going to hurt the car......just leave a few horses to be found latter. A tune will be appreciated by your car.
Originally Posted by lebvette
(Post 1587993838)
Lots of people running an aftermarket cam with stock exhaust manifolds, no worries with that. A cam will require a tune. You mention the heads were just redone...not sure what springs you wnet with, but that will dictate what cam you can run based on compatabiliy.
Originally Posted by MTPZ06
(Post 1587995496)
Thanks for the help |
I would get a custom cam spec'd to your car.
Friend has a cam/stock exhaust car. Still makes 550rwhp and runs really really good. Since you are in Florida, just call up Matt@FSP. He will be able to help. |
where did you get your head work done in in florida? im in destin and I don't know of anyone too close or even a few hours away.
I want to do a cam as well. |
I put in a mild cam at the same time I did my heads this past spring. Stock exhaust manifolds and intake, made 510whp on a mustang dyno and drives just fine (after tuning). My tuner said I should be around 550whp once I put an intake and headers on.
I put down 550 on a mustang dyno with stock exhaust. No issues but I do wonder what headers would do...
Originally Posted by rio95
(Post 1588002313)
Originally Posted by TRSCobra
(Post 1588002627)
That's really good. What size cam? Other mods?
(Post 1588002697)
Hell widow cam, wcch/vette air heads milled and ported, 107r intake, 93 octane
(Post 1588002743)
Dyno numbers are deceiving though so don't read into it too much...
Everyone has a favorite, but I'm gonna toss my vote in for EPS. Have Geoff spec a cam for your car and your needs. It may save you money in the long run...you wont be changing out cams one after the other. Good luck |
(Post 1588002743)
Originally Posted by JUSTAC6
(Post 1588001467)
Originally Posted by ZedNought6
(Post 1588003427)
I second this. I had a cam that made superior numbers, but the cam I have now drives SO MUCH BETTER! Losing 25 HP never felt so good. The car is far better to drive, really very smooth.
Everyone has a favorite, but I'm gonna toss my vote in for EPS. Have Geoff spec a cam for your car and your needs. It may save you money in the long run...you wont be changing out cams one after the other. Good luck Im thinking about getting Katech K501 Thanks for the help |
Originally Posted by wwx8989
(Post 1588009711)
Can you give a idea how much the labor gonna be for the cam installed?
