VetteNuts Insulation Kit Oct. SALE $99 Shipped!
We are putting our #1 selling kit on sale for the month of October. Only $99 shipped! This is the lowest price these kits have ever been sold for. Get yours today. C3 Pre-Cut Full Insulation Kit http://images.ibsrv.net/ibsrv/res/sr...es/patriot.gif The 1st & Original Kit! http://images.ibsrv.net/ibsrv/res/sr...es/patriot.gif $99 shipped in the continental USA. The C3 Pre-cut Insulation kit comes with everything you need to insulate and provide sound deadening in your Corvette, including Pre-cut pieces for your doors. We have made the 1st and the Original Insulation Kit for the C3, and our kit is complete with pre-cut pieces for your doors, which allow road noise to be reduced in your front cabin. Our kit gives you everything you need to completely insulate your interior of your C3 Corvette. We have sold thousands of these kits for C3,C4, C5 and C6 Vettes. This is the #1 mod for your Corvette! Our kit is a non-fiberglass, non-asphalt based product which weighs in at 3 lbs. (for those who are weight conscious), it rejects 97% of the radiant heat, and has a manufacturer's rating of 10db of sound and road noise reduction!!! The insulation is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & all pieces are clearly labeled for your convenience. It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!! Each kit is hand cut to our specifications, off of our own templates, and guaranteed to make a dramatic difference in your C3!!! Each kit comes with the following pieces:
Say goodbye to over-heated center consoles, and noisy front cabins!! Our C3 kit is the perfect addition to your C3, and is recommended for every Corvette owner as the #1 modification for their Corvette!!! Your Corvette will be cooler in the summer, a lot less noisy, and you will be able to enjoy your Corvette so much more. http://images.ibsrv.net/ibsrv/res/sr...ies/smile5.gif A lot of research and development has gone into this kit, and we are proud to say that our kit is made to our demanding specs, in house, and cut off of our own templates. It has 5 layers, and though it is rated at a 19db drop in noise, I have tested it in the Vettes at 8-11 db. reduction. Here are some manufacturer specs on it: Characteristics | Value | Regulation Cell Structure: Closed Nominal Thickness: 5 mm (+ or - 0.5mm) Steam Permeability: 0.033 gr/m2hkPa ASTM E-96 Noise Insulation: 19dBA IRAM 4063 at 50hz. Flame Spread Index/Class: 25 or less/ "A" - Class 1 0 ASTM E-84 Smoke Index/Class: 450 or less/ "A" - Class 1 15 ASTM E-84 INSULATION LAYERS Aluminum Foil polyethylene backing closed-cell Polyethylene foam polyethylene backing Aluminum Foil Order Your Kit Today Here! This is a C2, we need some photos for the C3's so please post yours. https://www.corvetteforum.com/forums...vendor-002.jpg https://www.corvetteforum.com/forums...vendor-004.jpg https://www.corvetteforum.com/forums...vendor-010.jpg https://www.corvetteforum.com/forums...vendor-006.jpg https://www.corvetteforum.com/forums...vendor-007.jpg *Premium Kit* :flag:Upgade to our #1 selling kit today :flag: When you want to do all you can to insulate your Vette look no farther! Two Kits Pre Installed together for Maximum Sound Deadning Here is another great Insulation package from VetteNuts. It is a peel and stick Ensolite IUO insulation material pre installed on top of our Foil Kit. When these two kits are combined together it will come as one kit. Road noise inside your Vette is drastically reduced along with a 10 to 14db drop in cabin noise. We also provide some scrap material for you to use anywhere you like! The Ensolite was designed by NASA for the space program.This is a very high grade foam/adhesive combination that will handle high heat, is fire retardant just like regular IUO. It resembles a wet suit material. This kit will make a huge difference in heat and road noise while adding only 9lbs to your Vette for both kits. Vettenuts has sold 1000's of these kits and there is lots of reviews on Corvetteforum.com. Pictured is a Premium layer installed in a C5. The Ensolite Pre is installed on top of the Foil kit making this one kit. We send out a roll of Ensolite 3" Wide that can be used as tape for the seams. :cheers: http://i858.photobucket.com/albums/a...924111411b.jpg |
Up and away!
2 Attachment(s)
ttt
2 days left!
