Timing advance question
Im compiling all of my car info and I came across my ignition advance numbers for my 327/340 in my 63. (it doesnt have the Duntov cam, some other solid lifter cam)
It runs pretty good as is BTW. According to my notes, I have 11* initial timing Mechanical adds another 14* all in my 3200 (IIRC) Vacuum can B26 provides 16* with 12" vacuum at 700 RPM. Would I be better of to have more intial, and less vacuum can? What would anideal combo be? I note that the B28 canis recommended, but its 16* advance also. Will I gain anything If I epoxy or weld the Advance can to limit advance to 11*, and advance the initial to 16*? This is the same dizzy that I will be using on my 383, so Id like to plan ahead to dial it in correctly. Thanks! |
I would think your centrifugal would.add a lot more than that to get you near the magical 36* "all in" number.
Originally Posted by DucatiDon
(Post 1588096954)
It runs pretty good as is BTW. According to my notes, I have 11* initial timing Mechanical adds another 14* all in my 3200 (IIRC) Vacuum can B26 provides 16* with 12" vacuum at 700 RPM. Would I be better of to have more intial, and less vacuum can? What would anideal combo be? I note that the B28 canis recommended, but its 16* advance also. Will I gain anything If I epoxy or weld the Advance can to limit advance to 11*, and advance the initial to 16*? This is the same dizzy that I will be using on my 383, so Id like to plan ahead to dial it in correctly. Thanks! The original 1963 distributor has a 24* centrifugal advance and you should try to get it all in by 3000RPM. This set up provides, 1, 27-29* idle advance, (12-14* initial + 15 vacuum) 2, 36-38* WOT advance, (12-14* initial + 24 centrifugal) 3, 51-53* total cruise timing, (12-14* initial + 24* centrifugal + 15 vacuum) |
Ok, so perhaps I was mistaken beliveing that 41-42 was the absolute max with vac.
You are saying 52* cruise is ok? I have the Lars paper here somewhere... Ill have to look inside the dizzy and see why Im only getting 14* advance. I doubt its the original distributor as well.....Id be surpised anyway.. |
48* at cruise is quite safe; 52* is "on the edge". My '61 handles 52* at cruise quite nicely but you have to be careful -- you don't want detonation or "trailer hitching"...
(Post 1588097193)
You are saying 52* cruise is ok? I have the Lars paper here somewhere... Ill have to look inside the dizzy and see why Im only getting 14* advance. I doubt its the original distributor as well.....Id be surpised anyway.. What carburetor are you using? If it's a tach drive Corvette distributor you can set the centrifugal advance curve without to much trouble. |
I have 12" vacuum at idle. Gm dist. Maybe original. AFB carb. 340hp car
If you have 12" vacuum you need the B-28 that's pulled full at approx 8" vacuum, that will keep the idle stable.
The original Carter AFB is part #3461. If you have this carburetor take good care of it because they are hard to find. Start there and target your timing like I posted above. |
My carb is a 3721 SB 64 250hp manual... I believe.
The 3721 will work just fine. If you have the original aluminum intake manifold consider wiring the heat riser open use a thick gasket between the carb and intake.
