Radiator hose suggestions please
Going to flush out my coolant system soon and want to do something for my coolant hoses since mine are stock on my 92 with 80,000 miles. Was wanting the CoolFlex stainless but have read horrible reviews how they slip off easily. I may just put the stainless sleeves over some new hoses but am wanting any opinions/references on the silicone hoses, usually red in color.
Thoughts and/or suggestions! |
I know that the stainless have a susceptibility to slip off at times. I would put on the best hoses I can find and then you can always cover them with an outer coating. When I would wire up my cars, I would find the plastic slip on covers that had the slip the entire length of the wiring or could be trimmed if necessary. Stainless does look pretty however if I had to change one out, I want the easiest and fastest way to do it. Just MHO!
Tommy |
Just hoses and quality clamps. You don't "need" the rest of the BS.
Gates, Dayco and Goodyear the major players. |
The stock ones lasted 22 years. Just replace with new factory hoses,the other stuff looks Mickey Mouse any way.
Originally Posted by WVZR-1
(Post 1588110690)
Originally Posted by sjohnson2615
(Post 1588115190)
I have always liked the look of a black clean hose! Tight fit easy to clean! How often do you look at hoses? The top of the motor and valve covers say it all!
Cool thanks for the opinions guys. Mine don't appear to be worn out, I was just considering changing since I am flushing but may just leave well enough alone for now.
Thanks again, I love this forum! |
Originally Posted by JUSBAD
(Post 1588116322)
(Post 1588118619)
Not "appearing" worn out isn't a very good reason to just leave them alone. If they're OE or even suspected of being OE then they're 22 years old and it's way past time. If you're unsure it's time for a change!
Also, how old is the pressure cap? Can't hurt to get a new one as they don't cost a lot. |
Although I still have the original hoses on my 85 I bought Goodyear replacements as well as a Goodyear serpentine belt that I will be changing over during the winter.
I put on blue silicone hoses. Bought from a Corvette vendor but forgot which one. Don't forget the anti-collapse spring in the bottom hose.
(Post 1588116322)
