Follow up to convertible top malfunction with GM answer
About 8 weeks ago convertible top glass and rear deck collided while using key fob. I've been back to the dealer 4 times with no luck on getting it right. GM finally sent a tech to take a look.
Just got call last night that they are going to change the entire roof and assembly...$7500.00. They finally admitted to me that this was the second one that had this malfunction. They think it is a software issue. My question is how many times does this have to happen to be a safety issue. I think one time is too many times. What if someone was driving up to a light and wanted to put down there roof and the glass exploded. I'm hoping they take care of all paint work also. I still have glass embedded in paint. Sorry for the rant-just wanted to let you guys know what is going on. |
Hopefully this actually fixes things for good, though if it's a software issue, it could happen again.
What about "loss of use"
Originally Posted by juststan
(Post 1588120188)
about 8 weeks ago convertible top glass and rear deck collided while using key fob.ive been back to the dealer 4 times with no luck on getting it right .gm finally sent a tech to take a look .just got call last night that they are going to change the entire roof and assembly. $7500.00.they finally admitted to me that this was the second one that had this malfunction.they think it is a software issue .my question is how many times does this have to happen to be a safety issue .i think one time is to many times .what if someone was driving up to a light and wanted to put down there roof and the glass exploded .im hoping they take care of all paint work also .i still have glass embedded in paint .sorry for the rant just wanted to let you guys know what is going on out there .
I have to ask, has anyone said anything about compensating you for the loss of use of your new ride? It sure seems like GM should be doing something there. Paul |
Stan, proper punctuation is your friend......
Lemon law? You should get a new car....
Originally Posted by Steven Bell
(Post 1588122334)
Originally Posted by zbrett
(Post 1588122356)
Surely you're kidding..... |
(Post 1588122458)
http://www.illinoisattorneygeneral.g.../lemonlaw.html |
Hopefully this will fix it and GM will also fix the paint issues. Sad that you've had this trouble with your car.
(Post 1588122458)
Thanks for the update.
I had a BMW hard-top convertible that I ran thru approx 6 - 8 cycles/day for a few yrs. Never had a problem. Hope this C7 vert top works as well. I'm just a little skeptical about "it's a software issue" answer. What's software got to do with it? It's mostly mechanical. You push a button, the mechanisms move. I think there's a problem between using the remote, & if you don't keep depressing the button the entire 20 seconds, or signal got disrupted. or both remote & in-car button pressed, paused, mechanisms got conflicting orders & hard top crushed the window... Anyways, still a defect. Hopes GM can fix... |
My top has worked perfectly. Not sure how sequencing works, switches or sensers. I can't belive a computer would cycle the system without some component feedback.
[QUOTE=Larry/car;1588123731]My top has worked perfectly. Not sure how sequencing works, switches or sensers. I can't belive a computer would cycle the system without some component feedback.[/QUOT
The GM rep said that during the cycle of holding the button down a cell phone or any kind of interference can interrupt the cycle.When i first purchased the car the salesman told me that the remote button to open the roof would not work every time. |
Hey guys i just want you to know that in no way im putting down the c7 or gm. I am just trying to deal with this the best i could for as long as i could.
just got the call new roof is in.gm tech will install.
[QUOTE=juststan;1588124880]
Originally Posted by Larry/car
(Post 1588123731)
Don't operate those devices near an airport either, otherwise you may cause a few planes to crash...
[QUOTE=JoesC5;1588140683]
(Post 1588124880)
Is the GM tech also going to install electronic jamming equipment while he's replacing the roof? If you can't operate the top reliably when it's in the presence of a cell phone or other electronic devices, then GM should install the necessary equipment to jam those unwanted signals. |
I had a problem about a week ago when I tried to drop the top with the key fob. It stopped mid function and wouldn't restart. I figured it was something I did so I hopped in the car and pressed the button and it continued to lower the top. Now I'm a bit worried????
Sorry to hear about the issues, but keep after them on the paint! They'll try to blow it off I'm sure.
