windows leaking
'93 both windows leaking water at top front. Have all new rubber seals on doors and top. Have heard of using silicone on the gap, but not recommended by some. Welcome a solution... Rain coming!
May not be able to get it to stop leaking....depending on what weatherstrip you installed. Some of the aftermarket weatherstrips are too dense and cause for sealing issues.
DUB |
Originally Posted by rnc
(Post 1588206041)
Is it leaking at the windshield header or the targa side? Or the windshield header weatherstrip to targa weatherstrip? When the roof is on and tighened the targa weatherstrip gets pushed against the windshield header weatherstrip to seal the join. If the side window does not go up enough or doesnt tilt inward toward the seals, you can adjust the window up limit and the tilt of the window. See image below, the circled area is the side window tilt adjustment and one of two height adjustement points. One is near the front of the door and is like an L bracket that limits the front part of window height. The rear guide has two screws that can adjust the hight, the screw at 90 degree angle can be accessed with a socket set to adjust the angle of the window inward or out. Note only a small adjustment makes a big difference.:cheers: http://i1230.photobucket.com/albums/...ps9d821220.jpg |
The main issue I have found is that the weatherstripping ( if it is not latex) can often times be too dense and not want to seal correctly where the targa roof and the 'A' pillar meet. It should not bunch up there....and that can be controlled by how the 'A' pillar weatherstrip is installed.
I AGREE with samsonb....that if aftermarket weatherstrips are being installed and they are NOT latex...the mounts for the targe roof MUST be re-adjusted ESPECIALLY if you have an acrylic top. IF you don't...with an acrylic top...it can crack and or have buckles form in time. Seeing how I do not install NON-latex weatherstrips at all...I can not verify if damage to a painted targa roof can occur. DUB |
Originally Posted by DUB
(Post 1588214457)
Originally Posted by Ozzstar
(Post 1588224927)
Which brand of weatherstripping do you use Dub, in this case?
I believe Ecklers also sells the Lone Star Caliper weatherstrips also.....and maybe Mid America. Possibly Corvette Central. I get them straight from the source. DUB |
Saving this info to see if I can fix my top issues. I have in the upper corner where the window, windshield, and top meet it leaks. also can hear the wind blowing in the car at highway speeds
Originally Posted by samsonb
(Post 1588227596)
How good are those weatherstrips?
I had thought Lone Star was getting bad reviews on here, but maybe it was a different brand. I do know putting rubber weatherstrips on the top doesn't mesh with latex on the A and B pillar. I think the ends on the rubber were to big/thick compared to the OEM latex and wouldn't let the top sit down all of the way. I ended up later on getting a top with the OEM latex and that sits down alot better into the A and B pillar weatherstripping. One bad thing at least with the Latex is the OEM stuff will form an impression. Real noticeable on the A pillar as the front lip of the top will leave an impression, and if you replace tops a few times, then the A pillar weatherstripping will get flattened out and not seal well. I think the front lips of the tops don't exactly sit in the same place from top to top. Especially with rebuilt tops. I have had my fill with the crappy weatherstrips that is out there and will NOT install it....they are too dense There is ALWAYS something that causes a problem in fit...or proper window operation, etc. Nothing is perfect...so if impressions in the weatherstrip are a concern...then install a weatherstrip that is so hard that nothing will an impression or seal against it....its out there. Damned if you do...damned if you don't. DUB |
