Under dash wiring question?
I was replacing bulbs under the dash and came across 2 wiring connectors that are not connected, anyone have any ideas? The purple and yellow connector is on the left side of the steering column the book it says this connection should go to the neutral safety switch but my neutral safety switch works correctly. And the second connector with the 2 light green and and 1 blue wire I have no idea where this goes. This is a 1979 with automatic transmission.
https://cimg0.ibsrv.net/gimg/www.cor...37c8ab19c1.jpg left side under steering column https://cimg3.ibsrv.net/gimg/www.cor...631a2aa27e.jpg right side of steering column above throttle. |
grn and blue might be the headlight dimmer switch, but you didn't say what yr your have and whether auto/manual
on a side note, I thought maybe they went together so i tried plugging them together and they fit, problem is it turned my starter on full time and did not sound good at all, other than pretty much everything works in the car as it should except the door chime/key chime. so I'm at a loss for what these could be, I have no rear defrost as the car didn't come with it so I'm wondering if one wire connector is for that even though the car wasn't optioned for it. the headlight dimmer works correctly without this being plugged in.
not sure if anyone has any idea on where these connections might go, anyone else?
Originally Posted by freddy4099
(Post 1588250255)
no one seems to know guess will have to keep studying wire diagrams |
purple and yellow wire connector is for the NSS when the car is equipped with a standard trans. GM put both plugs for stand./and auto in the same harness. just tape it up out of the way, my 79 has the same unused plug. i think the other connector with the 2 green wires and blue, is for the backup light switch when using a manual trans. just tape it up out of the way...... the auto trans. used one plug, the manual used 2 plugs.....:)
https://docs.google.com/viewer?a=v&p...TYyNWViMWY1NzY |
Originally Posted by speedreed8
(Post 1589366700)
https://docs.google.com/viewer?a=v&p...TYyNWViMWY1NzY PROFESSIONAL ADVICE: COME ON PEOPLE!!!!! One good way to set you car on fire...or melt down wiring is connect wire connectors together that do not belong together. LOGIC would tell you...if everything is working and fine....why join something together without knowing why they are there. Not each and every connector has to go to something. There are many...much like what is going on here....were put into the harness so GM did not have 2 specific harnesses for different options. They made one harness that accomplished both tasks. Like some say: "If it ain't broke....don't fix it". DUB |
Originally Posted by corvettesummer79
(Post 1589366605)
Ive been trying to identify plugs and wires under my dash too
no one seems to know guess will have to keep studying wire diagrams DUB |
Originally Posted by DUB
(Post 1589367505)
Need to see a photo(s) of the wire connectors in question.
DUB |
(Post 1589370915)
what is the female plug with a red black and white wire under dash?
C141 on the cruise control at brake switch is red black white. http://www.corvetteforum.net/c3/tune.../index21.shtml |
(Post 1589371064)
either the cruise control disengage or maybe the seat belt warning buzzer. are you sure about the colors. maybe its pink / black tracer. really need a pic.
oh well thanks for the assistance |
(Post 1589371101)
yes sure its a female plug with red black and white wire.
BUBBA 'knows' that you cannot have any loose wire ends anywhere in a vehicle. He would connect them to anything available...:ack:
Plug in under dash
I am having the same problem on my 1979.the wires are to short to go very far.i have a wiring diagram and so far no luck finding these wires or where they go.they don't go to the rear defogger my car has this and is working.the safety switch is out mine works just fine and is down by the shifter to far away. I removed the whole dash and couldn't see where they could go. time will tell as I get every thing else up and running.
Originally Posted by Esserville
(Post 1596139524)
DUB |
Wires under dash
(Post 1596139552)
It would be wise for you to start your own new thread...and post photos of the wires you are having a problem with...and keep in mind that taking close up photos helps out.... and also.... photos taken further away so we can see where it is coming from.
DUB The pictures were already on here just a few answers up. Thanks anyway I found out where they go. I |
