Alignment Shop in Orange County CA?
Brought the car to my normal alignment shop today, and he said he couldnt do it.
Does anyone have a recommendation for an alignment shop in Orange County that knows/is comfortable with C3's? |
If you don't mind a little drive Eckles Alignment in Ontario is the real thing. He did mine recently and it has never driven this well before. Older guy who just gets how to deal with all older cars.
Couldnt or didnt want to? Its a shame how many alignment shops are unwilling to align cars with shim style caster and camber adjustments. Just did mine on the alignment machine at work and other than rear toe these cars are very easy to align. Sorry I cant give you any direct advice other than to go to local shops and see if they are willing to do it. Be prepared to pay more than the advertised price as that usually only includes toe adjustment.
Eckles sounds like exactly what I'm looking for, just hoping to find someone local (Santa Ana, garden grove, Westminster or thereabouts ideally).
My guy said he doesn't have the program for anything before 1987. Also seemed nervous about the rear alignment. Not sure why. Seemed strange to me too. There seems to be a ton of vettes down here in oc. Hoping someone has a rec here locally. |
My guy said he doesn't have the program for anything before 1987. Also seemed nervous about the rear alignment. Not sure why. Seemed strange to me too. |
Giving you a bump. I am interested in finding a OC source as well.
The problem with setting the rear toe is that the original shims are no doubt rusted together and will not come out one at a time.
Most of the time the bolt is frozen to the bushing so I has to be cut out. Shops won't let a mechanic spend hours trying to replace those parts. Change the bushing yourself, order and install new stainless steel shims and a new bolt and tell the shop everything is new. Then most any shop will take care of your Corvette. |
Miller's in North Long Beach if it's within your driving range. Old time shop.
Corvette Mike's in Anahiem CA does Corvette alignments. Ask for Carl.
Thanks for the recommendations.
I called all 3. Based on the calls, I'd REALLY like to go with Eckles, but he is slammed and can't take me until after the first of the year. His price was $50 for front, $100 if 4 wheel. He was super helpful, clearly knew his stuff. Corvette Mikes was expensive. They quoted $200 for 4 wheel. They don't have the greatest yelp reputation, which is a drag (the others both have good ratings). Millers will be likely where I end up. They quoted $50 for front, and can do it while I wait today. Has anyone used vodies in garden grove? |
One thing Eckles mentioned that was interesting that I wanted to ask for opinions on.
I mentioned the Borgeson box, and that Borgeson recommends the 3-4 degree castor, and he said he doesn't agree with that. He said it makes the steering too sensitive and darty, which is exactly why I decided to upgrade to the Borg box in the first place. I want the bump steer and dartiness gone. What say ye? |
J&D Corvettes in Bellflower, Ca...that's pretty close to Orange County. J&D is a CF sponsor. I'd recommend them because they are close to Orange County. Acquaintances of mine have had their alignment done there and were happy. I had my 68 alighnment done by Guildstrand Motorsports in Burbank Ca. Had to flatbed the 68 to there and back.
Holleys tire in San Clemente is great shop for suspension and tires. Sorry but they never did my corvette alignment (all my other vehicles though) so u need to give them a call first.
949-492-4733, http://www.holleystireservice.com/au...alignment.aspx |
I have been to J&D before to buy parts. I didnt realize they did alignments. Great suggestion. I will give them a call on Friday.
Might not be the best of ideas, but I took the car out for a 100 mile run today pre-alignment (I was testing out the electric fans I just installed, and today was a little warmer day). The bump steer is really noticeable. I am really hopeful the alignment will remedy that issue. That was the main reason I installed the Borgeson box and rebuilt the front end. I also came across another thread on this forum recommending a shop in Orange. I called today but they were closed (closed until monday for the holiday). Accurate Alignment on N. Batavia St in Orange. They have great Yelp reviews, and a bunch of photos of older cars on their Yelp profile. That seems promising too. Ill be calling them also on Monday. |
Might not be the best of ideas, but I took the car out for a 100 mile run today pre-alignment (I was testing out the electric fans I just installed, and today was a little warmer day). The bump steer is really noticeable. I am really hopeful the alignment will remedy that issue. That was the main reason I installed the Borgeson box and rebuilt the front end. |
Rear allying meant
My trailing arms were rusted in bad. I had to torch everything out including the bushings and shims. I finally succeeded with lots of smoke and fire. Now to put it all back together. How many and where should I place the new shims to get it to the alignment shop. I have all new parts to install including shims
Reg |
Ended up getting the alignment done at Accurate Alignment in Orange CA. Sharon (wife of the owner) is incredible. Very helpful, knowledgeable, and all around quite personable....and its a good thing she is there. It helped counter balance a little funkiness with Chris, the owner. I must have caught him on a bad day. He got easily frustrated, which he directed at me in the form of funky remarks and attitude, felt the need to throw in a few unnecessary small jabs and digs on a couple of things, but that aside, he does know what he is doing.
He struggled with my spreader bar for some reason. First he asked me what it was and what it did (I was surprised by the questions), then struggled removing it for more than 30 minutes (Its just a simple nut and bolt that hold the hemispherical ball joint to the bracket...pretty simple stuff). However, all that being said, he really did take the time necessary to get the alignment right, and for that, I appreciate his effort. He charged me $25 more than he quoted me, but I didnt say a word. Just paid the $125 for the front end only. I knew he put some time into it..I was there for 2 hours. All and all, a significantly improved alignment. Just wish his rack-side-manner was a little more even-tempered and customer friendly. I dont want to be too hard on him, just reporting my experience as it happened. Overall, Im sure hes a good guy, and I assume I just caught him on a bad day. He did accommodate my request to wait for it instead of dropping it off, got me in the same day I called, and he was thorough once he got past removing the spreader bar, and did get me really close to the Borgeson 3 degree castor they recommended. I really can feel the difference in how the car drives. Id give them a solid 3.5 star rating. If it wasnt for the funky vibes from the comments and the attitude, it would give him a 5 star rating. Im not entirely sure Id go back to him again, but I am happy with the result. |
Zero 1 Niner
How is the dartiness (tramlining) on the rough roads now? Did the extra castor make it any better in your view? What size front tires are you running? I ask as I'm fighting the same tramlining problem, with the Borgeson system installed, and hope a new alignment will make it better. |
Originally Posted by Kim72
(Post 1588652517)
Zero 1 Niner
Tires are 255 60 15
