Rusty procharger piping
Just bought a car and found the meth has corroded the piping.
Can I get the insides powder coated. Or what's the best route to go? |
sand it out and paint it! or get new piping, powder coating may cost too much. A&A sells all the pipes.
Originally Posted by Travis_C
(Post 1588666401)
single stage
single stage enamel with hardener meth won't touch it, four years and no problem.
Originally Posted by leo12
(Post 1588668396)
(Post 1588668396)
(Post 1588688712)
How do you get paint inside the pipe?
Originally Posted by a/c man
(Post 1588688729)
Fog the hell out of it hahaha
https://cimg6.ibsrv.net/gimg/www.cor...4b2909bbb6.jpg |
I have some aluminum tubing and can make some for you.
Originally Posted by JeremiahsC5
(Post 1588695296)
Don't blame you. I wouldn't want to put flaking rusted pipe back in the intake stream either. 304 stainless is such a minimum price increase, should be standard.
If it were me I would replace with stainless or aluminum and never worry about it again. None of that would be hard for a fabricator to replicate. |
I can only make straight sections. Good luck with your search.
(Post 1588706212)
Thanks |
Looks like you could buy alum per-bent mandrel bends & fabricate what you need pretty easy
(Post 1588666401)
Can I get the insides powder coated. Or what's the best route to go? Poor coatings, salt water, etc.. Hows the meth going to rot the pipe externally? |
Originally Posted by Julio
(Post 1588712143)
Meth didn't do that :toe tap:
Poor coatings, salt water, etc.. Hows the meth going to rot the pipe externally? https://cimg3.ibsrv.net/gimg/www.cor...9b991a6443.jpg |
Maybe he was running water through it?
I run all alluminum, except for the top tb inlet pipe, which is steel. I have meth as well, uncoated inside the pipe, no rust after 5 years. |
Originally Posted by SmoothFRC
(Post 1588715762)
There is an old saying.. Whiskey mixed with water isn't whiskey.
Methanol mixed with water isn't methanol. So when you said "meth" it was interpreted as 100% meth. Boost juice, washer fluid, etc etc is not "meth" Maybe the water mixed with the meth unlocked the reaction to the uncoated steel. I have never seen a rusty pipe like that since i've been doing this... and thats close to 15 years and "thousands.." of people in contact with. But again I don't deal with "mix" |
(Post 1588712496)
The rust inside is what concerns me.
