F/S C5 Front Caliper Hardbar T1 AP Racing 8350+Bracket
For sale used AP Racing 8350 Caliper modified to fit new Brackets and stainless DOT Brake Line. Price is 600 + my shipping fees (from Montreal, Canada)
My original Hardbar bracket had cracked and i could not find any replacement that fit for them. Hardbar is close, Essex tell me that their new bracket will not fit..... So i had via my friend who own a shop done something. He put me in relation with one of is client (Massive Brakes) who make many kind of high quality brackets and add on for the BMW market. I ask him to design me a bracket to fit the new Wilwood caliper that is almost the same dimension as the AP Racing 8350 but with 6 Pistons.They had a 4 pistons caliper too with the same surface ratio of the C5 oem rear caliper that is built on the same caliper core, so the brackets will fit on the 4 corner... The best thing is that it will fit the same disk and pad as the front.(But your losing your parking brake.) When I receive my bracket I was curious to see if it will fit the AP Racing caliper .... And yes it almost fit perfectly... I had some modification to do on the AP Caliper (dremeling) but wow it fit.... So With this kit you have a bracket that could fit the AP Caliper and the Wilwood superlite 6 pistons. https://cimg4.ibsrv.net/gimg/www.cor...1f496f53d5.jpg https://cimg5.ibsrv.net/gimg/www.cor...ca0d45421f.jpg https://cimg6.ibsrv.net/gimg/www.cor...34305e83c6.jpg https://cimg7.ibsrv.net/gimg/www.cor...8160a02966.jpg https://cimg8.ibsrv.net/gimg/www.cor...6b7b162c8d.jpg https://cimg9.ibsrv.net/gimg/www.cor...461812589d.jpg https://cimg1.ibsrv.net/gimg/www.cor...a0be1ce3a4.jpg https://cimg5.ibsrv.net/gimg/www.cor...2a2f566cf0.jpg https://cimg6.ibsrv.net/gimg/www.cor...b63b94db07.jpg |
Bump
I could sell the bracket separately for those who broke them.
Price for brackets only please.
Brackets price
325$ shipped for a pair with all the mounting bolts and Nord-Lock washer ( cost me about 50$ For all of them )
Originally Posted by Patane
(Post 1589534439)
Forget to tell the caliper are sold only the bracket and fitting
I bought a set of these last year and they work great. I know of another NASA ST3 car using them also...
Originally Posted by ScaryFast
(Post 1591328247)
Don't forget that you could use those bracket in the back with the wilwood super lite 4 Pistons galiper ( with the same surface area then oem rear caliper ) and in bonus use the same disk and pad shape as the front... That what I do and I could rotate all my piece front to back to use it at the maximum. |
Spring bump for those bracket if you need it i still have it
Still have bracket for 325$ shipped
still have some
what rotor/hat package do you run w/ these brackets and the wilwoods?
i run the stoptech two part rotor but could use any stock one two """same circumference ""
Originally Posted by y5e06
(Post 1594844060)
If it runs the OEM rotors you could buy the Performance AFX rotors someone has for sale on here now, and have a very cost effective big brake kit.
Still have 2 pair
