Cargo hatch lights don't work
Hey all. My cargo lights don't work on my 89. The hatch release works, all of the other interior lights work. The interior lights come on when each door is open and with the headlight/dome light switch. The cargo lights won't work with the hatch open or any of the switches on. I'm not getting any indications on the dash with the hatch open either. They have never worked since I have owned the car. Does anyone have an idea or a schematic for this? Thanks!
Not to be a smart azz but have you checked the bulbs and the sockets for 12V? I always check the simple stuff first because we often overlook the obvious. I would then check the plunger switch at the hatch release mechanism altho if they dont light with opening the door, I would think they wouldnt be the issue. It may be dirty or damaged. Check for 12v there as well. Other than that its just a hunt and peck to find out where the problem lies. You may find where your PO has disconnected a wire because of a short or something.
Good luck! |
I don't have power at the lights. I have tested the ground through the plunger and it's working. I was looking for a schematic to find where they get their power from.
On my car there is a module that controls the rear hatch lights (on the right):
http://www.misterpeachy.com/VettePic...ease_Relay.JPG |
Cliff, would it be logical then at this module there will be 12v and two input circuits, one from the doors/lightswitch and one from the hatch plunger?
no lgts
Originally Posted by HlhnEast
(Post 1589081657)
Originally Posted by 70ZZ3 96LT4
(Post 1589082165)
These lights stay on to long after I shut the doors.
Originally Posted by MDstar2
(Post 1589080638)
Does your power antenna work? Does your spare tire lamp work? (Just in case: it's located in the center of the car, under your rear bumper). These two things are wired to the same spot in your harness, and also should have 12v. at all times. Need an answer to this before proceeding. :cool: |
Originally Posted by Hot Rod Roy
(Post 1589084345)
You should have 12v. at the cargo lamp sockets at all times. They are switched on by a ground circuit thru the diode module shown in Cliff's picture (the module at the right in his photo).
(Post 1589084935)
I have not seen the spare tire light either.
:cool: |
Right now the car is parked in the back of the garage against the wall. I'll bring it back out when the snow goes away. I have looked for the spare tire light and have never seen anything lit up under the car. I'll start there when I move the car. I would guess I need to look at that module and the connections there if I don't have power at the spare tire light.
The diode module has nothing to do with the lack of 12v. at the hatch lights sockets or the spare tire light socket. The diode module is on the ground side of the lamp circuitry. If you don't have 12v. at the sockets, your lights can't work.
It is strange that your antenna will go up and down. All of these devices get their 12v. from connector C124 pin D, which is located behind the RH end of the instrument panel. I'm wondering if someone may have cut the wires to your cargo lamps, because they couldn't figure out the hatch switch. You'll probably have to remove the plastic "halo" panels to check this out. :cool: |
(Post 1589089278)
Hi
There are differences with the courtesy delay timer's. My original one would light the hatch area with the door opening, the second hand replacement delay timer is different. Open door and floor lights door lights and mirror lights work, the rear hatch cargo lights only work when the hatch is opened. The delay is around 30 seconds for the lights to go out when the car has been locked. See the Corvettecentral website below, regarding different part numbers for the courtesy lights delay timer board. :thumbs: http://www.parts123.com/corvettecent...ar=&part=delay timer&searchtype=50 http://www.parts123.com/corvettecent...50f&ukey=29998 http://www.parts123.com/corvettecent...50f&ukey=29596 |
Originally Posted by gerardvg
(Post 1589090789)
If there is tampering at his hatch switch, he would still have 12v. at his cargo lamp sockets, so that's not the stated problem. There may be other problems, but they aren't related to his lack of 12v. at the cargo lights. :cool: |
The spare tire light looks like this (the orange glow is not normal -- the bulb was bad):
http://www.misterpeachy.com/VettePic...Tire_Light.JPG As Roy mentioned, this light should come on any time the interior lights are on. |
Originally Posted by Cliff Harris
(Post 1589100517)
(Post 1589089278)
It is strange that your antenna will go up and down. All of these devices get their 12v. from connector C124 pin D, which is located behind the RH end of the instrument panel. I'm wondering if someone may have cut the wires to your cargo lamps, because they couldn't figure out the hatch switch. You'll probably have to remove the plastic "halo" panels to check this out. :cool: Ok....... I apologize. I was wrong. After tearing the freaking car completely apart, it does have 12 volts to the lights. On both sides of the sockets there is 12 volts. Even with the bulb out, there is 12 volts on each side. So I'm definitely missing the ground, not the positive. |
(Post 1589290536)
Ok, it does have 12 volts to the lights. On both sides of the sockets there is 12 volts. Even with the bulb out, there is 12 volts on each side.
Don't worry about connector C124. If that was bad, your antenna wouldn't work. :cool: |
(Post 1589075046)
If it is, it is likely bad. It controls ground to cargo lights and dash indicator. Here is the schematic from my 86 manual. http://members.shaw.ca/dankai/Interior%20Lights.pdf |
