Post Pictures of Gauge pods please
title says it all... time for some gauges... looking for ideas on gauge pod placement. :cheers:
lol thread over. lol what does that gauge all show? and where can i get one?!
https://cimg3.ibsrv.net/gimg/www.cor...e528710b78.jpg
Commanded Lambda, Wideband reading, knock retard degrees and boost/vacuum in psi https://cimg1.ibsrv.net/gimg/www.cor...ba306a3eac.jpg |
I like the idea of dash logic.. but you need an aftermarket MAF sensor correct?
Originally Posted by Suprfly
(Post 1589169102)
(Post 1589169045)
If you decide to not use a gauge the dashlogic is what I would use. |
Originally Posted by schpenxel
(Post 1589169108)
Why would you need an aftermarket MAF?
(Post 1589169152)
to read boost? am i misinformed?!?
MAP=air pressure Yeah, you do need a different MAP sensor to read boost, but most should really consider one of those anyways if you're going with a supercharger. If yours is an 05/06 you need a sensor that a few people around here make, or I can give you the part number for the sensor if you really want to be brave and try to make your own. They cost about $100 from people on here. If your car is newer than that then I think you can just use a ZR1 sensor which should be cheaper. |
(Post 1589169179)
MAF=air flow
MAP=air pressure Yeah, you do need a different MAP sensor to read boost, but most should really consider one of those anyways if you're going with a supercharger. If yours is an 05/06 you need a sensor that a few people around here make, or I can give you the part number for the sensor if you really want to be brave and try to make your own. They cost about $100 from people on here. If your car is newer than that then I think you can just use a ZR1 sensor which should be cheaper. MAP.. i knew that didnt sound right.. my car is a 2009. |
My setup... DashLogic to read boost and other parameters via DIC and HUD, plus PLX wideband w/ SLP pod for AFR/lambda. The SLP pod is a nice alternative to cutting a giant hole in your dash.
https://cimg2.ibsrv.net/gimg/www.cor...f5ee5ca24c.jpg |
that is very nice, where did you get the pod? Streetk14
(Post 1589169238)
my car is a 2009. |
(Post 1589169269)
(Post 1589169238)
my car is a 2009.
Originally Posted by Streetk14
(Post 1589169284)
Then just get a $30 ZR1 map sensor. It's better to do that anyway, since it can actually allow the PCM to see true boost pressure.
Ok, im almost sold on the dash logic with the zr1 MAP sensor. but would I have to have my car retuned? I just spent $500 on tuning....
(Post 1589169304)
(Post 1589169304)
If you're running the stock OS then it shouldn't do anything different with a boost reading tune wise since there are no boost tables. I'd have to see your tune to be sure. Dash logic will be able to pick up the reading though and display it, which of course is the point. |
i guess a call to my tuner is in order. thanks guys!
