cam or intake manifold
Wondering if I should do cam and springs first or a msd atomic airforce intake? What would need a tune afterwards -baller on a budget
Both would need a tune. Cam/sprimgs you'll see more gains.
Intake 1st. The stock ls2 intake is not the best. I had an 06 A6 with similar mods, I did the ported fast 92 1st and the car ran great. You would want to upgrade the manifold when doing a cam anyway. Get it out of the way now.
Unless you decide to go FI. |
It's a 07 a6. I got longtube headers,high flow cats, exhaust, cai. Would the fast require a tune to function? I plan on getting a tune just don't want get a tune and a month later put in cams and springs and need a retune. I'm looking at then new msd atomic airforce manifold
I did a dyno overlay of all my mods from headers to heads. See below.
It's wise to remove airflow restrictions in the proper order, which is headers, then cam, then intake, then heads. Going out of order doesn't make sense, for example, Trickflow heads are great but on a stock cam they aren't the bottle neck so you won't notice the difference. See how they stack up on the dyno, and note the last three only matter from 4500 rpm up. There is other good discussion in this thread as well so read on if you care to. https://www.corvetteforum.com/forums...ast-heads.html |
Thanks I will Def check that out
It doesn't matter what order you do your mods. Keep in mind that a cam will have a lot bigger gains on a stock motor than an intake swap would on a stock motor. I can't really see the MSD Atomic giving you much until you have other mods to make it shine. Granted there might be a slight increase but you will need a dyno sheet to tell it. You will feel the powerband extended the first time you hammer down with a cam swap.
Personally, I would go with a stall first. Then cam, then heads, then Atomic
Guys he said LS2 MOTOR...intake stocks is junk! Yes cam will net more power but a fast will still net 20hp on a LS2.
Damn that MSD intake is a nice piece of work. A little too expensive for me though. I gotta stick with the FAST 92/102. Go with the intake before the cam, but if you can afford both, get it done, tune it and be done with it.
Or track down a LS3 intake and buy a cam.
What i would do.
Buy a 3,400 stall headers ls3 heads and intake manifold appropriate cam port throttle body slap it all in at ones and tune it.
You can just swap out LS3 heads and intake onto a LS2? Is that the difference between the LS2's 400 hp to the LS3's 430hp?
Originally Posted by Chokeu
(Post 1589237358)
Edit-Misread. |
Originally Posted by AJG87
(Post 1589237727)
No. Heads are required as to accompany the intake. The above poster was missing that little piece of info..
unless you have other mods like headers & CAI, I would do the Intake 1st. The gains will be marginal, but the swap will take an hour or so. If and when you do a cam swap, the added volume of the intake will yield higher gains. Think of an engine as an air pump, the faster you get air in & out the higher output it will have.
Originally Posted by lowes48
(Post 1589232823)
(Post 1589237358)
Thanks for all the responses :thumbs: currently thinking cam spring install with torque converter and maybe gears with tune. Any thoughts ? I'll do intake later in year or next?
Originally Posted by CMY SIX
(Post 1589242097)
you have to butcher your fire wall to install the fast,
