Tow hooks in stock for later Z51!
We have the tow hooks in stock for the Z51 C7. They can be ordered at www.zl1addons.com if you buy 2 you will get a shorter one for the rear to not look so bad like the OEM
If your Z51 was made after 12/14/14 it will have receivers from the factory and all ZO6s have them also. There is a thread about them in the Z06 section. Pics there also. Our tow hooks are made better than the OEM and hinged. https://www.corvetteforum.com/forums...r-the-zo6.html |
Is that date 12/15/2015 correct or should it be 2014 instead? My Z51 was built on 2/2/2105 and has the threads for a tow hook.
Originally Posted by Zulu51
(Post 1589444305)
If your Z51 was made after 12/14/14 it will have receivers from the factory and all ZO6s have them also. There is a thread about them in the Z06 section. Pics there also. Our tow hooks are made better than the OEM and hinged. https://www.corvetteforum.com/forums...r-the-zo6.html[/QUOTE]
I need more info. My 2015 Z51 was made before 12/14. Do I have any receivers? If not, how can your tow hooks be attached to the car? |
Can you PM me details on the new hooks for the Z51 as they are not listed on the web site? Pricing etc. Am looking for the long and short ones (pair) to have them both installed for track days.
Originally Posted by Skylane765
(Post 1589444811)
Yes 12/14/14. Sorry about that. I just got used to writing 2015 on checks and missed that one, thanks for the heads up.
Have you tested the tensile strength? Is your tow hook stronger than OEM? If so, I will order them. |
yes, our premium is stronger, the standard is fine for track or pulling on a trailer. The D ring is not our design so can not tell you the strength. no one knows the strength of the OEM either. I do know the D ring on the standard is good to 8k lbs but do not know beyond that.
Our premium will pull the front end off before it would break. |
(Post 1589447397)
Originally Posted by LB001
(Post 1589445102)
we are working on the receivers now. when I get a ZO6 I will have more info on when and how much. |
(Post 1589454638)
I ...working on the receivers now. when I get a ZO6 I will have more info on when and how much.
Originally Posted by Rob Willis
(Post 1589457608)
No guess? I've got some early summer track days coming and wonder if I should wait or order from other vendor. Thanks!
(Post 1589457608)
(Post 1589460101)
I could use a owner around San Diego to mach up and get free tow hooks and receivers. Anyone out there close by?
Originally Posted by AliZ51
(Post 1589460144)
I have 2015 Z51 with production date 12/1. It does have the receivers front and back. I am just about to order the two hooks from your website.
My Z51 was built 11/14 and I have the rear receiver for sure - grey metal block with threads behind the cover in the back, and threaded metal hole in the front, and removable section of the front grill.
Update - Spoke to the manufacturer on the phone, and if aligned properly they fit. Great quality product and prompt/outstanding phone support. |
I received the Premium front/back tow hooks. Great quality product, but it did not fit my factory 2015 Z51 (11/14 build) receivers.
Edited: After a phone call with manufacturer, got them both to fit front and rear. They have some play in then until you screw them in high all the way. The rear needs to be angled exactly right to fit - it goes into an angle to the receiver, but in line with car. (I feel like an idiot for trying to get them in last night and conceding they didn't fit) https://cimg4.ibsrv.net/gimg/www.cor...78d5b48952.jpg https://cimg6.ibsrv.net/gimg/www.cor...dd3d8a6e05.jpg |
Originally Posted by baron95
(Post 1589822064)
I bought my car new from the dealer, never driven with 2 mi on the odometer, so I am sure the receivers are whatever GM put in the Z51 in Nov/2014. As you can see in the pictures, the rear receiver is too small for the ZL1 tow hook screw. It won't even go in. Also the threads are very different - more closely spaced in the receiver. At the front, the ZL1 tow hook will go in and can be threaded, but if fits loosely - the threads are mismatched - again more closely spaced in the receiver. So, unfortunately, I need to return these. https://cimg4.ibsrv.net/gimg/www.cor...78d5b48952.jpg https://cimg6.ibsrv.net/gimg/www.cor...dd3d8a6e05.jpg One other note, I can see by the pic you do not have the tow hook lined up with the receiver. It is important to know that the tow hook lines up at a 20 deg angle down and STRAIT IN LINE WITH CAR! not 90 deg with bumper like you have in the pic. NO, our threads are not miss matched they are correct and fit them all. the front is loos until you tighten to the lock pin we have installed. If the tow hook fits the front, it will fit the back and if it will thread into the back it will fit the front. |
(Post 1589827839)
The threads are all the same on all the Corvettes, they are m20 2.5 you can check that by using a nut and you will see they all fit our shaft. If you had the car here I can show you how they go in. The rear just has a lot of paint on it and you may need to chase the threads. By the way our shaft is made .010 under size. OUR TOW HOOKS WILL FIT YOUR CAR!! You just need to line them up correctly, all Corvettes are the same and we have over 300 tow hooks being used, so it can not be our threads, I guarantee it. Call me and I can help you install them. 858 527 8727 GM just did not clean the paint out.
(Post 1589828268)
All set - see edits above. Thanks for the very helpful phone call.
(Post 1589828408)
The member now has the tow hook installed! here is a video of how to install https://www.youtube.com/watch?v=_476...ature=youtu.be
