C7 Tips & Tricks
The C7 Corvette has plenty of well known attributes, but there are some lurking behind the scenes. Here's a running list of tips & tricks that you might not have known. Post what you've found, and I'll add it to the list.
Not in manual
In manual (but often overlooked)
Misc.
"Favorites" can be used to save more than radio presets. For example, you can save Nav Destinations (like Home), contacts, tone settings, artists, songs, etc.
Originally Posted by alienranch
(Post 1589456677)
[*]Turn signal will chime if left on for more than 3/4 mile
That's actually pretty cool though. |
Originally Posted by Woodson
(Post 1589456811)
:rofl: GM catering to the demographic.
(Post 1589456677)
[*]Audio - Favorite (Next/Previous) steering wheel controls obviously change stations/tracks. They also allow for advancing a track forward or backwards if held down.[*]Navigation - When viewing the navigation screen, your nav application tray icon ('N' arrow) can be pressed to toggle between the map views without having to go through the settings menu.
Let me see if I can contribute... If you keep your windows open and lock the car. If you try and reach into the car it will trigger the alarm. I found this out at a gas station the other day...:lol: |
If you disconnect battery for an extended amount of time (mine was for 4 days) both Trip A and B mileage changes to total miles from odometer.
Originally Posted by Nosferatu
(Post 1589464829)
Part I bold'ed I did not know. Rest I did. Thanks! Keep this thread going! :)
May be already known, but when Rev Match is on in manual transmission car, the gear number you are in turns orange.
:cool:info. Thanks.
you can search your USB songs/artists on the right side of the DIC as well as using voice commands.
Originally Posted by Zymurgy
(Post 1589456794)
Hmmmm... I managed to get 3 "NAV" favorites to show up on the Favorites Bar. The only problem is they all show "NAV" as the title. Can that be edited to say a name, like Bob or Mary rather than the "NAV". I'm old, I'll never remember the damn order I save those things! Elmer |
Originally Posted by eboggs_jkvl
(Post 1589471174)
When the set button is pushed for the cruise control, the speed that is set flashes on the the dash panel for a few seconds
If you have the screen down and you shift into reverse the screen will close so you can see what's behind you.
If you press your car icon on your navigation it will display the street your on , instead of showing what radio station your on . Press the car icon again and will go back to what music is playing
(Post 1589471708)
(Post 1589471708)
C7 Tips & Tricks
you can edit the fav buttons to read whatever you want. Mine read
Jim's 2014 C7 Vette |
Originally Posted by TNSQUIRE
(Post 1589472387)
(Post 1589464502)
Never understood why more cars didn't do this. Such a common problem with a simple solution.
