Intermittent Air Conditioning Problem
Hi Everyone,
We have a very annoying problem with our 2013 C6. The air conditioning randomly will stop blowing air out of the dash vents and will only blow the cold air out of the defrost and floor vents. There is no rhyme or reason as to when this happens. The A/C might work fine on the way to the store but when the car is started after leaving the store the air will not blow out of the dash vents. Trying to change the vent controls has not effect. Eventually the air will just start to blow as it should out of the dash vents. It might go 3 or 4 days before it does it again, or it might do it twice in one day. Has anyone else experienced this? I can take it to the dealer but I figure if it does not happen to be doing it at the time they won't be able to find anything. Thanks for your input! |
What setting is the HVAC controls in?
Hence, take it off Auto mode, and switch it over to a manual modes instead. Also, the memory of the HVAC system is tied into the fob, so if you are switching the fobs when you are driving the car, then the car is setting resetting to the last setting when that fob was used for the car. Note: fob 1 will always be the primary fog, So if your wife has Fob 1 in here purse in the passanger seat, you are in the drivers seat with Fob 2, the car still thinks that you are in the drivers seat with Fob 1, and will use the last setting for Fob 1. |
Originally Posted by The Inspector
(Post 1589556196)
Hi Everyone,
Hi Dano - We have tried all of the manual settings to no avail. And this happens when only one of us (and only one fob) are in the car.
Bill - You "bought a new" what and installed it? Thank you for your input! |
(Post 1589558126)
(Post 1589556196)
Hi Everyone,
Thanks for the info. I made an appointment with the dealer for next week. It is still under warranty so we'll see if they can find anything.
