Diff. lube
I believe my 2005 C6 Vett has AC Delco synthetic oil in the Differential. I have been told to use only AC Delco Dexron LS Gear Oil 10-4034. Is this oil a synthetic oil and if not will it harm the differential that had synthetic in it before. Hearing lots of clunks coming from the Diff. and want to change the oil. Thanks.
Different lube change
Originally Posted by wwhuff
(Post 1589562494)
I just did mine also, used GM fluid. I've heard Red Line a good product also: Read More here:https://www.corvetteforum.com/forums...-specific.html
There is lots of good info regarding this subject. |
(Post 1589562494)
Thanks for the info. Hope that solves my problem.
Last month I had my 05 have it's 50,000 miles check-up including Diff and Trans fluid change at the Dealership, so I hope they would use proper fluid, they should know what to use.
i am new to this. Why change it out?
Originally Posted by Coach Borne
(Post 1589567162)
