Cheapest way to add Bluetooth Audio Stream?
Purchasing a 2008 z51 vert with factory Nav
Unfortunately, GM didn't include aux or bluetooth streaming back then. I know Ray Kawal has a solution involving the purchase of a Personal Audio Link, upgrading to version 2, and then installing -- looks to cost about $400, all in I also have seen some slick Pioneer and Kenwood units that replace the factory unit and add the functionality i'm looking for - that looks to cost at least $600 Are those pretty much my options? Or is there something I'm missing? |
Originally Posted by Cauhauna
(Post 1589563993)
Unfortunately, GM didn't include aux or bluetooth streaming back then. I know Ray Kawal has a solution involving the purchase of a Personal Audio Link, upgrading to version 2, and then installing -- looks to cost about $400, all in I also have seen some slick Pioneer and Kenwood units that replace the factory unit and add the functionality i'm looking for - that looks to cost at least $600 Are those pretty much my options? Or is there something I'm missing? that's about it. My car came with PAL pre-installed from factory (from previous owner). I just slapped the Bluetooth module to it and voila. That was originally my idea that Kawal then integrated into his little thing. :) |
Originally Posted by Nosferatu
(Post 1589564118)
I went with Pioneer and skipped the nav since I have it on my phone. Saved me some money and then upgraded the other components while in there.
Here you go for less than $110,
http://www.tigerdirect.com/applicati...FcKIaQodEZkAGw https://www.corvetteforum.com/forums...005-13-c6.html Also, if you don't use the cigarette lighter, nice place to install the extra USB port, the extra acc in port, and could ever set the reset button to the left hand side of the USB plug. https://cimg0.ibsrv.net/gimg/www.cor...7641b2e9b0.jpg |
Originally Posted by Dano523
(Post 1589564723)
(Post 1589563993)
Unfortunately, GM didn't include aux or bluetooth streaming back then. I know Ray Kawal has a solution involving the purchase of a Personal Audio Link, upgrading to version 2, and then installing -- looks to cost about $400, all in I also have seen some slick Pioneer and Kenwood units that replace the factory unit and add the functionality i'm looking for - that looks to cost at least $600 Are those pretty much my options? Or is there something I'm missing? https://www.corvetteforum.com/forums/c6-corvette-general-discussion/3221583-bluetooth-kit-for-2005-13-c6.html?styleid=139 Costs around $115 from DoubleD mods. About three hours or so to install keeping in mind that the 08' models have a Phillips head for the shifter screw and it got stripped out really easily. I ended up having to drill the head off and remove the whole shifter later to use an easy out bit for the rest of the screw. I would advise trying to heat it up a little before you try to to remove it. Other than that the install was super easy and I have had no problems with it at all. I put the USB port in where the cigarette lighter is under the AC controls and ran the aux cord into the center console. Haven't really used either one since the Bluetooth works so well. Routed the mic up the pillar and clipped it in the corner above the onstar mic. It uses your XM channel and you can still use XM like normal. Congrats on the new car! :thumbs: |
There's an aux button in 08's.
Originally Posted by not08crmanymore
(Post 1589565798)
Very, very, very helpful! Thank you.
And you are correct on no nav/aux until 2011 (what were they thinking?) |
Originally Posted by mwvette556
(Post 1589565527)
I went with the isimple ISGM655.
https://www.corvetteforum.com/forums...ml?styleid=139 Costs around $115 from DoubleD mods. About three hours or so to install keeping in mind that the 08' models have a Phillips head for the shifter screw and it got stripped out really easily. I ended up having to drill the head off and remove the whole shifter later to use an easy out bit for the rest of the screw. I would advise trying to heat it up a little before you try to to remove it. Other than that the install was super easy and I have had no problems with it at all. I put the USB port in where the cigarette lighter is under the AC controls and ran the aux cord into the center console. Haven't really used either one since the Bluetooth works so well. Routed the mic up the pillar and clipped it in the corner above the onstar mic. It uses your XM channel and you can still use XM like normal. Congrats on the new car! :thumbs: ^^^^^^^^ i also went with this device and i love it. i posted my modification. which was to drill inside of the console area for both the usb port and aux jack that comes with it. i also placed the microphone in the same place as the oem microphone, just clipped it to the trim on the A pillar here's the thread i made back last year after i hooked mine up. i like it inside the console. https://www.corvetteforum.com/forums...-c6-cheap.html the more i have become familiar with it the easier it is to use.. also i now have an android based smart phone which makes using the bluetooth easier. still works awesome. very happy with my purchase a year later and would do it again |
(Post 1589566084)
Originally Posted by RobLo
(Post 1589564189)
Could you please explain this a little more? I have a PAL 2 from Ray for my IPod/phone connection, how would I integrate Bluetooth into this? Is it a separate module, do I have to purchase something else or can I wire (plug) my phone and using the existing car mic/speakers? Thanks!
I installed an aux port. Works fine. I usually just burn mp3 music to a CD and listen to that. You can put a lot of mp3 music on a CD.
It is nice to have the aux input though. Only costed a few bucks to install. You can search the forum for details on the aux install options. |
(Post 1589564189)
Go to Best Buy and get this... http://www.bestbuy.com/site/aluratek...=1218987691917 Plug into the PAL Pair your phone and done. You're phone will be paired to "General Motors" (car) and to that adapter named AIS03F. Audio will pump to the adapter and if a phone call comes in it'll seamlessly use the car. Here it is in action when I first did it... |
(Post 1589565798)
Kawal has multiple options so 400 total is not lowest cost method.
Kawal sells premade $80 AUX-2 VRT which plugs into xm wiring harness in waterfall of your convertible and provides connector for plugging in audio device via cable. Then purchase kinivo BTC455 bluetooth adapter $50 Amazon to plug into input of Aux 2 VRT. So around 130 plus shipping and you have hands free calling and bluetooth music. Note you must have xm selected as input when using to hear audio via speakers. To listen to xm instead of bluetooth unplug Kinivo audio cable from aux input of the aux 2 very wiring harness. Addition details http://www.kawal.net/bluetooth.htm http://www.amazon.com/Kinivo-BTC455-Bluetooth-Hands-Free-Input/dp/B00JK0G8KC If you are going to spend hundreds of dollars and get new head unit check out thread below for ultimate versatility via Android head unit https://www.corvetteforum.com/forums/audio-electronics/3501820-android-head-unit-and-backup-camera-installation.html |
Originally Posted by montivette
(Post 1589570785)
Kawal sells premade $80 AUX-2 VRT which plugs into xm wiring harness in waterfall of your convertible and provides connector for plugging in audio device via cable. Then purchase kinivo BTC455 bluetooth adapter $50 Amazon to plug into input of Aux 2 VRT. So around 130 plus shipping and you have hands free calling and bluetooth music. Note you must have xm selected as input when using to hear audio via speakers. To listen to xm instead of bluetooth unplug Kinivo audio cable from aux input of the aux 2 very wiring harness. Addition details http://www.kawal.net/bluetooth.htm http://www.amazon.com/Kinivo-BTC455-.../dp/B00JK0G8KC The Isimple does the same for under $110, and you don't have to unplug the kinivo BTC455 every time you go to shut the car down. Plus, with the BTC455 into the XM harness, your only sourcing in the analog sound off the phone to the radio, and have no controls of the phone through the radio controls instead (much less and digital data in from the phone like how is calling, and what sound is playing that will display on the radio). Plus with the I simple, you gain a USB port for adding more devices hard wired in/charging your devices, and even a Aux port for grins as well for devices that don't have a USB way of digital connecting to the radio. And let face it, the PAL was pretty much out dated shortly after it was released (has no blue tooth on it, nor updated itself to include blue tooth), and just a expensive device for the limited amount it does do to begin with. By the time you start adding harnesses, and such, your deeper into the hole for hundreds more (read instead of digging this rabbit hole, just update the head unit to an aftermarket deck instead (with tons of more features). So the Isimple ISGM655 with blue tooth is the evolution of the the Pal/ISGM575, and does not have a jacked up price on a old outdated piece of electrons with GM name on it instead. The downfall, all require you to manually switch to the XM channel on the radio for these to work. |
(Post 1589567711)
To summarize...
Go to Best Buy and get this... http://www.bestbuy.com/site/aluratek...=1218987691917 Plug into the PAL Pair your phone and done. You're phone will be paired to "General Motors" (car) and to that adapter named AIS03F. Audio will pump to the adapter and if a phone call comes in it'll seamlessly use the car. Here it is in action when I first did it... Only question, I know Ray sold cords that charged, and some that did not, so does it matter which cord you have to work with the blue tooth module? |
(Post 1589573894)
Looks like a great option for adding Blue tooth to Pal,
Only question, I know Ray sold cords that charged, and some that did not, so does it matter which cord you have to work with the blue tooth module? My cord does have charging capabilities so I can't say for certain that the non charging ones will work since theres no power. |
