High NOX - EGR?
Hi all,
My 92 LT1 failed inspection for the 2nd time.....high nox. I am thinking it is EGR related, as I have replaced everything else..... Question 1 is, do I just the replace the valve itself or do I also replace the vacuum solenoid? Question 2 is, how hard are these jobs? Thanks! Much appreciated. |
See if you can get the valve to open at idle by either using a vacuum pump or by pushing on the diaphragm. Does the engine run rough or stall? This tells you that the egr passages are open. Some engines have been known to get clogged up.
Tee in a vacuum gauge to the egr valve connection & take it for a drive (must be up to temp) & see if you get a vacuum reading under acc. & cruising conditions. Egr isn't supposed to open at idle, when the engine is cold, or at wot. |
Originally Posted by ex-x-fire
(Post 1589600580)
How high is it? Mine is usually a couple points below the max. I have the test station put a shop fan in front during the test or it will fail. The problem is you have to get the cats hot and keep them hot while waiting in line and the motor is getting too hot. Yes the fans come on at 228 but if your motor has high miles and parts are worn it may be border line pass or fail on the nox, the shop fan helps a lot. My tech even runs a hose on the radiator though I do not think it is needed. Since I take all 9 of my cars to him he gives me great service.
Originally Posted by kimmer
(Post 1589601435)
I wouldn't think that the EGR valve would open during a test. I could be wrong on that. I've been wrong before...
Originally Posted by Cliff Harris
(Post 1589604918)
Did you replace Cats? I had a 96 Dodge Dakota 318, I drove back from Il. to
Cali and it failed because the salt had dissolved the cat, new cat pass smog. Good luck |
Originally Posted by xrav22
(Post 1589612550)
Originally Posted by cicch95
(Post 1589600517)
Hi all,
fAILED TWICE
(Post 1589600517)
Hi all,
Another thing that can cause high NOX is running lean. Not sure of CT but in CA in the 25mph test or in the non-enhanced areas the 2500 rpm test is specifically designed for the EGR to open. EGR opens at moderate throttle (1500-3000rpm). It will be closed at idle and full throttle.
