Anyone ever remove power antenna rubber bezel?
The rubber part around the exposed part of the antenna? I have the part # but I'm unsure if you just remove the top nut and it pulls off or not.
Thanks Dave |
Hi
If it's the same as a zo6 it just pulls out the top , think its easier if the anttena is dropped down out of the way , so you can pinch the rubber in. Might be able to remove without having to do that though. Can get access if you remove rear right side lamps if you have to . :cheers: |
Originally Posted by NITRO UK
(Post 1589605066)
Hi
If it's the same as a zo6 it just pulls out the top , think its easier if the anttena is dropped down out of the way , so you can pinch the rubber in. Might be able to remove without having to do that though. Can get access if you remove rear right side lamps if you have to . :cheers: Dave |
