59 Overheating & fuel problem
Hi C1's
I have two problems with My 59 282 single quad First it gets very hot when in traffic but as soon as I drive it cool down. I changed the thermostat same problem. New aluminum radiator same problem. I have a original 4 fan blade. Should I put a auxiliary fan assembly? Second problem; I could drive my car all day at a normal rate of speed but if I put the petal to the metal it pops , bogs down & wants to stall, when that happens I have to go in the slow lane, slow down for a minute or two than I can continue. Fuel pump, Vapor lock ? History of motor; Complete rebuilt 2013 Thank you Michael |
Originally Posted by Michael 59' corvette
(Post 1589660879)
Hi C1's
I have two problems with My 59 282 single quad First it gets very hot when in traffic but as soon as I drive it cool down. I changed the thermostat same problem. New aluminum radiator same problem. I have a original 4 fan blade. Should I put a auxiliary fan assembly? Second problem; I could drive my car all day at a normal rate of speed but if I put the petal to the metal it pops , bogs down & wants to stall, when that happens I have to go in the slow lane, slow down for a minute or two than I can continue. Fuel pump, Vapor lock ? History of motor; Complete rebuilt 2013 Thank you Michael Second problem could be spark plugs, plug wires misfiring under load, ignition coil, sticky advance weights, fuel delivery/fuel filter and a few other things. :thumbs: |
Overheating at low speeds or idle could be a timing issue. Start at 10* to 12* advance. If you have a vacuum advance distributor you should be at 20* to 25* at idle with the vacuum can connected. Make sure your advance can is connected to a non-ported source at the carb. You should be "all in" at 36 to 38 degrees at 2500 to 2800 rpm.
Do you have a fan shroud? Can you feel air moving into the grill?
Originally Posted by INMYBLOOD
(Post 1589661015)
Yes I do have a shroud but a 1959 has no clutch. thank you Michael |
Originally Posted by Frankie the Fink
(Post 1589660919)
First problem could be an inaccurate temp sending unit; verify temps you are seeing with a cheap I/R temp gun (Harbor Freight) has them...shoot the thermostat housing...you might not have an overheating problem at all. If that verifies your problem - might be time to look at your fan clutch and a few other things...
Second problem could be spark plugs, plug wires misfiring under load, ignition coil, sticky advance weights, fuel delivery/fuel filter and a few other things. :thumbs: Yes I do have a shroud but a 1959 has no clutch. |
Regardless of any other problems, you would be a lot better off running a 60 style 5 blade fan and fan clutch assembly instead of the original 4 blade fan. I do that in my 59 and it really helps. Zero issues cooling even on a hot day idling in traffic. :thumbs::smash:
