What goes on this boss?
2 Attachment(s)
Putting the car back together after doing a cam & head swap. I don't remember what goes on the boss shown in the photos. This is on the left side of the car below the power steering pump and ABS module. I don't see any remaining parts that look like they bolt up to this boss. I was careful to put all of the parts I removed together in one location so as not to lose any, but this has me stumped. Your help is greatly appreciated.
The ABS bracket for my 2000 uses those holes. It has 4 bolts that hold it to the cross member. The abs for later models only uses the two that you have already used.
You're good. I had the same freak out when I did my swap.
Thanks guys! That helps.
