C6 power driver seat not working
I recently purchased a 2006 corvette from a forum member. Just a few days after purchase, the driver power seat started to work only intermittently and now doesn't work at all. Luckily I saved my memory presets before it stopped working. The seat moves when the memory buttons, including the exit button, are pressed. The lumbar buttons work as well. But, the front/back/up/down button does not wrk at all. Can anyone provide any help? Thanks in advance for your help...
Originally Posted by Ask12b1
(Post 1589710916)
Here is the thread, wiring diagrams, and pics. Hope it helps: https://www.corvetteforum.com/forums...t-working.html |
Originally Posted by LV2TOUR
(Post 1589711056)
I responded to a similar thread this month.
(Post 1589711246)
Thanks! I read the link. So, if it doesn't move in any position, does it mean that one wire could be loose, or does it mean all don't work? How would I check each connector in the wiring harness? Also, is there a way to check the switch itself to see if it could be the problem? If I could eliminate the switch, it would mean that it would have to be in the wiring harness, correct? If it's a switch, I'll do it myself. If it's in the wiring, I may have to leave it to a "professional".
Good Luck :cheers: |
The first thing I'd check are the main power wires going into the memory module. It's the plug in the middle. On my car those wires were severed off. I'm trying to dig up the posts I made about it with pics when I had a very similar issue. I'll reply if I do find them.
mine did a similar thing,, but I don't have memory.. Seat would not move while I was sitting in it, but would if I adjusted if when standing out side.. the motor connector had gone bad and it needed a new motor.
When memory is use does the seat move back/forward up/down? If so motor is fine.
I would check the connector under the seat. Make sure it is tight and no broken wires. Many people have put a zip tie on the connector. |
Originally Posted by SEVINN
(Post 1589713218)
Thank you to everyone who has responded. I will certainly begin looking at the module connectors before I attempt to remove and replace it and/or the switch (hopefully save a little "dough" in the process after having just purchased the vette).
To LV2TOUR's point, you mention "lifting" the seat...do you mean removing it or is there a way to lift it somehow without unbolting it? Please forgive me, I'm somewhat new at the whole "working on a car" thing, I am really excited about it, but cautious at the same time...don't want to create a problem I can fix, or have fixed, inexpensively if I don't have to. |
(Post 1589716405)
To LV2TOUR's point, you mention "lifting" the seat...do you mean removing it or is there a way to lift it somehow without unbolting it? Please forgive me, I'm somewhat new at the whole "working on a car" thing, I am really excited about it, but cautious at the same time...don't want to create a problem I can fix, or have fixed, inexpensively if I don't have to. :cheers: |
Perhaps I didn't take any pictures, but here is my thread. You'll see a good writeup that a fellow member was able to make by combining our experiences. Our problems were the fact that the seat wouldn't move and we couldn't get to the bolts because it was stuck too far back.
Thanks for the subscriptions idea LV2TOUR it helped alot. I normally go through the hard way and look through individual posts. https://www.corvetteforum.com/forums...post1583267248 |
(Post 1589766308)
Thanks for the subscriptions idea LV2TOUR it helped alot. I normally go through the hard way and look through individual posts. https://www.corvetteforum.com/forums...post1583267248 I'm glad that the subscription idea worked for you. It's an easy way to find out what threads you were on. I purge mine every once in awhile, just to keep them manageable. :cheers: |
