*** SOLD *** FS: Everything for Manual Trans to Auto Conversion!
*** SOLD ***
Looking for EVERYTHING to convert your manual shift vehicle over to an automatic? I have the 4L60E transmission, torque converter, torque tube, differential, flex plate, shifter, knob, boot, linkage, brake pedal assy, bellhousing and wiring harness (i.e., EVERYTHING!) that you'd need to turn your manual shift vehicle into an automatic, or just to completely replace your old worn-out system with low-mile parts. The differential is the "performance option" version for the automatic, the vehicle itself is a 1998 Vert (one owner) and had just slightly over 36,000 miles at the time of swap. The car has never been raced or to the track - in fact, it still had the original EMT tires with about half the tread left. In short, these parts haven't seen much action... Due to the low price this all goes as a set - local pick up only. $1,250 takes everything! Thanks! Jeff http://i1154.photobucket.com/albums/...7/a057e983.jpg http://i1154.photobucket.com/albums/...7/b5404503.jpg http://i1154.photobucket.com/albums/...7/a6896af4.jpg http://i1154.photobucket.com/albums/...7/f1598b6d.jpg |
Where are you located?
I'm assuming you went from auto to 6 spd?
Replies
@ Almost There 1 = I'm in the Metro Detroit area.
@ megrog2 = Yep, I finally decided to do the swap from auto to manual a couple of summers ago. No regrets! |
Originally Posted by kalayaan12
(Post 1589782424)
This is "one stop shopping" for all the parts you'll need!
I wished you were closer! GLWS
MIKE |
Originally Posted by comecorrect
(Post 1590924239)
MIKE |
pm sent
Conversion help!
I have a couple questions about the swap you did. If you could give me a call or text @ 209-269-9543
Originally Posted by Calderon209
(Post 1591166010)
Jeff |
*** REPOSTING THIS AD ***
After tripping over this stuff in the garage for the past couple of years, it's time to put it back up for sale again (pick up in Metro-Detroit area only)! Everything you need to go from a manual to an automatic :) Thanks! Jeff |
I responded to you private message. thanks for reaching out. I may be interested in the trans if your ready to split it up.
Bumping back up to the top!
ttt
ttt
ttt
Ttt
*** Re-opening an old thread ***
Cleaning out the garage in preparation for an overseas assignment - I can deliver trans / torque tube / flex plate / pedals / shifter / harness / etc., as a set (I'd prefer to sell everything at once) within a reasonable driving distance of the Detroit-Metro area if needed (and pending lifting of COVID travel restrictions). $1250 takes all, and I'll even throw in a reasonably decent set of wagon wheels mounted with Michelin Pilot Sport A/S Plus P275/40 ZR18's with new aftermarket sensors and maybe a few hundred miles on them. Thanks again! Jeff |
I wish you were closer.
