hoosier a7 starting pressures auto x
anyone have any good feedback for some starting pressures for c7z on autocross tire pressures.
havent ran any a's for autocross before dont want to be too out of range on the 1st outing on these. thanks |
I run 31/27 most of the time, with camber, etc... on 315/18 front 345/19 rear.
32/28 as a starting pressure for the 275/17 - 315/18 on a C5z...
The usual caveats apply, your mileage and pressures may vary.... |
thanks guys will give those a whirl
wow a7's are great i didnt have any more camber set in then factory and could tell for wear on outer edge i pumped to 35 to start since didnt have as much camber bumped up to 40 for fronts 36 rears. seemed to wear good then.
i took out the 2 washers behind a arm last night for todays auto x will have to check wear. didnt have time to get proper alignment. should have between -2 and -2.5 up front now atleast. |
