Brake pad shape on the none Z07 2015 Z06
Does anyone know the pad shape on the regular Brembo's in the none Z07 brakes?? Thanks, JD
I responded to your mail but I believe the fronts are the same as the gen 2 CTS-V.
Front is CTS V gen 2/ ZL1 Camaro. Back is C7 base/Z51. If you are interested in Carbotech pads I will be happy to help you out.
Carbotech part #'s Front CT1405 Rear CT1718. |
Thanks for the info!!! JD
