LT1 spark plugs
I have a 72 LT1 and some years ago at Carlisle I purchased a set of AC plugs 44TS.
Now looking it up in the service manual the plugs listed are AC R44T for a 72 LT1. The ones I have AC R44TS are for a 71 LT1. Would there be any issues in using the R44TS instead of R44T in my car? |
they are the same plug except the R44TS is extended tip (the 'S').
I would run the R44T if it were me and return the R44TS...but I don't own an LT1 so can't say for sure if it would be a problem...but would hate to hit a piston with too long a tip! |
Visually compare the two plugs, the overall length maybe the same, the R44TS may have less of the metal casing surrounding the ceramic exposing more of the ceramic tip. I have a 70 Lt-1 short block running an early version of Chevrolet angle plugs heads and have always used the TS series of plugs.
