Katech Titanium 12x1.5mm 12pt lug nuts. Finally, an affordable, quality Ti lug nut!
https://cimg1.ibsrv.net/gimg/www.cor...da53b290bc.jpg
In the past, racers and weight nuts have paid up to $500 for titanium lug nuts. We are now offering these high quality pieces at a very affordable price of $6.99 each. http://store.katechengines.com/titan...15mm-p490.aspx |
Originally Posted by Katech_Jason
(Post 1589921344)
Originally Posted by db2xpert
(Post 1589933966)
How much lighter are they on a per wheel basis?
Wowzer, you'll sell a buttload of these.
Lug nuts are now available in carbon black.
-SOLD INDIVIDUALLY -16 grams each Not just any black lug nuts. These are coated with a high tech, proprietary Diamond-Like Alloy coating utilizing the latest coating technology to provide a very durable surface. -Very low coefficient of friction -High mechanical hardness (2600 Hv) -Coating thickness: 1-5 microns -Surface roughnes: Ra~.03um, Rz~.2um https://cimg5.ibsrv.net/gimg/www.cor...77b00074e8.jpg https://cimg9.ibsrv.net/gimg/www.cor...8b09af64ed.jpg http://store.katechengines.com/titan...lack-p510.aspx |
Are these compatible with extended DRM or ARP studs?
Originally Posted by mdaniel
(Post 1590220437)
Ordered.
Can you confirm that these require a 17mm 12-point socket? Thanks |
(Post 1590221126)
Ordered.
Can you confirm that these require a 17mm 12-point socket? Thanks China? Hey, somebody has to ask. |
(Post 1590221126)
Ordered.
Originally Posted by froggy47
(Post 1590221273)
:lurk:
China? |
How would the black finish hold up with frequent use of an impact?
Originally Posted by fruitsalad
(Post 1590221335)
Jason -
Any change in target torque values w/DLC coating? |
(Post 1590221280)
Yes.
Originally Posted by StreetSpeed
(Post 1590222330)
Well that explains that (as well as the vibrations in the threads)! If you're selling them for $7 you must be buying them for $2ish. A $2 Chinese lug nut that keeps the wheels on my car scares me.
Originally Posted by mgarfias
(Post 1590221703)
Jason -
(Post 1590222330)
How do you know your current lug nuts are not made in China?
Originally Posted by Werks
(Post 1590222425)
Have you ever seen Katech put out any type of sub-par, low quality product before....ever???
I don't want to blow up your spot - sorry about that. I own a CNC machine shop and have done lots of work with Chinese parts and Chinese material. Best of luck.
(Post 1590222465)
No
Also, why are the threads cut instead of formed? |
I don't necessarily disparage every part made in China, just want to know what I am putting on my car.
I have been buying the cheap steel ones & tossing them every year replacing with new cheap steel ones. ARP studs seem to last many seasons and I an VERY CAREFUL how they (nuts) go off/on. So if I spring for these will they go for 2 - 3 years? If, yes, then it could make sense for me. Any testing? My own personal testing on the cheap steel ones is 2 years max. This is assuming you change your wheels a lot, racer, not the guy who keeps the same wheels on his car until his tires wear out. So testing as to durability, not how strong a brand new one is "one time"? :thumbs::thumbs: BTW Men's Health just published a small article listing Corvette (and F150) as two of the top 4 vehicles with the most USA made parts content. :flag::flag: |
