1987 Coupe - White / Red - LOTS of Pics - NEEDS ABSOLUTELY NOTHING!! (Re-Listed)
*** SOLD!!!!! ***
*** ADDITIONAL INTERIOR PICS ADDED in POST # 12 **** I am re-listing my 1987 once again. To explain briefly, I was selling because my bride of 30 years (and BEST friend in the world!) has Osteoarthritis and has a difficult time getting in and out of the car. Seeing her struggle pained me, and the reason I bought this was for "us" to enjoy, so the initial decision to sell was easy. BUT, she fought me tooth and nail about selling, and asked me to forgo the sale of the car, so I yanked the original ad. Well, since then her OA has gotten worse, and getting in and out has become even more of a struggle...she still wants me to keep it, but I can not enjoy what I got for us to enjoy together, so I vouch that it will remain for sale until sold. Having explained not only the "re-post", but now also giving folks insight into the reason for the sale, let us now move on to the ad: :yesnod: --------------------------------------------------------------------------------------------------------------------------------------------------------- 100% STOCK, NO MODS, UNMOLESTED. 163,8xx miles. Arctic White with flame red interior. Believe it or not, ORIGINAL carpet. Extremely well maintained. The one year old professional Arctic White paint is beautiful and shines like a mirror...it's BRIGHT!! The pictures of the exterior actually do the appearance no justice. White cars are tough to photograph to show the true quality. You must see for yourself in person, there will be NO disappointments!! Lets start with the particulars. Here is a list of parts that have been replaced and maintenance items that have been performed on this car, broken down by section: ENGINE / FUEL DELIVERY • New Bosch III (22lb) Injectors • New Fuel Pressure Regulator • Engine top end resealed/new gaskets from block up. • Replaced Valve Seals • New Distributor Cap • New Rotor • New Spark Plug Wires (Packard) • New Spark Plugs • New PCV Valve • New O2 Sensor • Tank drained and cleaned • New AC Delco Fuel Pump / Pick up Filter • New Fuel Filter • New Air Filter • Recent Oil Change with Filter • New AC Delco "Red-Top" Battery • Newer cat-back chambered exhaust. Very nice low rumble, NO popping, sputtering, etc... on deceleration. Eliminates mufflers!! TRANSMISSION • Trans fluid and filter change WHEELS TIRES SUSPENSION • New BF Goodrich P255/50/ZR16 Sport Comp Tires • New AC Delco Shocks • Recent 4 Wheel Alignment BRAKES • New Brake Rotors (ALL) • New brake Pads (ALL) • New Bendix Master Cylinder • Original Calipers Rebuilt (ALL) • Fluid Purge-Flush-Fill (DOT 3) COOLING SYSTEM - HVAC • New Heater Core • New Heater Shut-off Valve • New AC Delco Water Pump • New 195° Thermostat • New Radiator and Heater Hoses (ALL) • New (NOT REMAN) A/C Compressor • New A/C Condenser • Receiver/Drier • New Orifice BODY / INTERIOR • New Seat Belts • Newer Seat Covers • New Headliner • Custom Stainless Steel Vinyl Covered Color Keyed Sill Protectors • Newer Floor Mats • New Hatch Lift Assist Cylinders • New Hood Lift Assist Cylinders • New Driver Door Hinge Pins/Bushings • Rebuilt Headlight Motors - Both Next up is a list of the bells and whistles it has. Read on... OPTIONS LIST: AC1 : ADJUSTER, PASS ST, POWER, 6 WAY, BKT AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER AQ9 : SEAT, FRT PASS A DRIV, RECL AQ9 : SEAT, FRT BKT PASS DRIVER RECL AU3 : LOCK CONTROL, SIDE DR, ELEC CC3 : ROOF, HATCH, REMOVABLE PANELS. PLASTIC CF7 : ROOF, SUN REMOVABLE NON-TRANSPARENT C2L : ROOF, PACKAGE DUAL REMOVABLE C49 : DEFOGGER, RR WINDOW, ELECTRIC C68 : HVAC SYSTEM, AIR CONDITIONER FRT AUTO, ELECTRONIC DL8 : MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG D74 : MIRROR, I/S, LH SUNSHADE, ILLUM FG3 : SHOCK ABSORBERS, FRT & RR, GAS PRELOADED GM1 : AXLE REAR, 2.59 RATIO K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC K68 : GENERATOR,105 AMP L98 : 5.7-LITER V8 TPI ENGINE MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4 PY3 : WHEEL, 16 X 8.5, CAST ALUMINUM QZD : P255/50VR16 TIRES/16” WHEELS UQ4 : SPEAKER SYSTEM, BOSE, 4 UU8 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC Z6A : REAR WINDOW AND SIDE MIRROR DEFOGGERS 245 : ROOF COLOR,BLUE, REMOVABLE PANEL 40U : PRIMARY COLOR, EXTERIOR, WHITE (91) 73I : INTERIOR TRIM, FLAME RED (I) (91) 732 : TRIM COMBINATION, LEATHER, FLAME RED (2) (91) EVERYTHING WORKS on this 87...right down to the V.A.T.S. and both power lumbar seats. All of the engine parameters are 100% within GM specs outlined in the Factory Service Manual. All of the weather seals are tight and this car is 100% leak free. The A/C is ICE COLD! (Well, close enough anyhow. I realize…we see this claim time and time again, but I have included a pic of a thermometer I placed in the center vent to PROVE it blows COOOLD!!) Outside temp yesterday was 86º at the time it was taken. The original BOSE radio was removed by the prior owner. I replaced the radio with a freshly remanufactured Delco AM/FM/Cassette unit. The rear speakers are NEW Delco 6x9s, the door speakers are Delco 6 in round units. The radio sounds GREAT! The antenna was upgraded to the later 1988 and up style, and at the time I installed it I also installed a new Delco replacement mast. The car originally came with both tops (plastic and solid) but currently only has the solid as seen. I also have a storage cover for the top that's included. • Fuel economy ranges from 16-17mpg in town to 21-23mpg on the highway at 70mph. • Coolant Temp = 198° and Oil Temp = 204° steady at 70 mph This car needs absolutely nothing but a driver. Its an absolute joy to get behind the wheel of and drive. Look at the pictures below...ask questions...Come and see it in person. Take it for a drive. I would not hesitate to drive this car to any point anywhere in the US. I think that's about everything. If I think of something else I may have forgotten, I'll add it in. SOLD!!!! http://img.photobucket.com/albums/v2...Corvette/1.jpg http://img.photobucket.com/albums/v2...Corvette/2.jpg http://img.photobucket.com/albums/v2...Corvette/3.jpg http://img.photobucket.com/albums/v2...Corvette/4.jpg http://img.photobucket.com/albums/v2...Corvette/5.jpg http://img.photobucket.com/albums/v2...orvette/5a.jpg http://img.photobucket.com/albums/v2...rvette/5a1.jpg http://img.photobucket.com/albums/v2...rvette/5a2.jpg http://img.photobucket.com/albums/v2...rvette/5b1.jpg http://img.photobucket.com/albums/v2...orvette/5c.jpg http://img.photobucket.com/albums/v2...orvette/5d.jpg http://img.photobucket.com/albums/v2...rvette/5d1.jpg http://img.photobucket.com/albums/v2...orvette/5e.jpg http://img.photobucket.com/albums/v2...orvette/5f.jpg http://img.photobucket.com/albums/v2...orvette/5g.jpg http://img.photobucket.com/albums/v2...Corvette/6.jpg http://img.photobucket.com/albums/v2...Corvette/7.jpg http://img.photobucket.com/albums/v2...Corvette/8.jpg http://img.photobucket.com/albums/v2...Corvette/9.jpg http://img.photobucket.com/albums/v2...orvette/10.jpg http://img.photobucket.com/albums/v2...orvette/11.jpg http://img.photobucket.com/albums/v2...orvette/12.jpg http://img.photobucket.com/albums/v2...vette/13_1.jpg http://img.photobucket.com/albums/v2...orvette/14.jpg http://img.photobucket.com/albums/v2...orvette/17.jpg http://img.photobucket.com/albums/v2...orvette/15.jpg http://img.photobucket.com/albums/v2...orvette/16.jpg http://img.photobucket.com/albums/v2...orvette/18.jpg http://img.photobucket.com/albums/v2...orvette/5g.jpg |
That is a beautiful 1st Vette for someone....well maintained, clean, and a great price.What more can you ask for.:rock::cheers:
Someone will be getting a great car. Shouldn't last long. Nice picture display and listing. This is the way to market a Corvette.:cheers:
Thanks for the kind words, I really appreciate them!
:cheers: |
if it was only closer she would be in my garage.very nice!
Originally Posted by jimbosr
(Post 1589949273)
What a beautiful car! It's obvious you cared for it throughout the years because of your love for it. I'm sure it is hard to let it go but I admire you for selling it because the love for your wife is far greater. I truly hope that your wife can feel better soon. Best of luck.
Originally Posted by Dt86
(Post 1589962242)
Again, thank you my friend! :yesnod: |
Originally Posted by White87
(Post 1589969121)
Dt---thank you for the kind and true words, and for noticing the care that has gone into this car. It actually will be hard to part with, for both of us. The ones that are easy to let go of are those which are a constant source of problems and expense...this one is neither. This is solely my decision to sell. My bride wants me to keep it, but like I said earlier, if we can't both enjoy it...:(
Again, thank you my friend! :yesnod: I very interested in the vette!! lovely car! |
Originally Posted by Zuma12
(Post 1589981790)
:cheers: Dave |
:thumbs:
Perfect
Is that vehicle still for sale? My daughter would love that for her 16th birthday
Originally Posted by Kingk30
(Post 1590007931)
Thanks for the interest! :cheers: Dave |
White C4
Please let me know if the sale does NOT complete as I'm willing to fly to your area and drive this beauty home to Pennsylvania!
Sincerely, Terry |
Originally Posted by PopsTJ
(Post 1590065670)
Sincerely, Terry I will call this sale "COMPLETE" once the new owner has title in hand, and is happily on his way back to Atlanta. Stay tuned, we're getting close now! :D |
What a nice "first time" vette! And a great deal. Congrats and best of luck to you both!
That vette is coming to my city? I'm excited for her to be here. She's a beauty. Also. Let me know when the deal goes through. If not. I'll be coming from Atlanta to bring her home. 👀
(Post 1590067923)
(Post 1590068172)
I have had members PM me about my car as well, and if for some unforseen reason the deal doesn't occur, I will be contacting members in the order they have contacted me. THANK YOU TO ALL for you kind words and interest! I will keep this thread updated. Dave :cheers: |
Thanks DT!
