C7 Z06 Corvette Painted or Carbon Fiber Lower Grille at RPI Designs
https://lh4.googleusercontent.com/az...9-B7l-anJtvwpO C7 Z06 Corvette Front Grille Painted Body Colors or Carbon Fiber Are you looking to change the look of your C7 Corvette Stingray? Would you like to give it the Z06 look? Here at RPI, we have you covered. You can order a C7 Z06 Corvette front grille in plain black plastic, any C7 body color or hydrocarbon fiber. If you are looking to purchase one painted or hydrocarbon fiber, please allow additional time as we make the order. Item # C7-Z900 COUPON CODE RPICHRIS5 at checkout for an Immediate Discount. Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5043 https://cimg1.ibsrv.net/gimg/www.cor...511dceb994.jpg https://cimg4.ibsrv.net/gimg/www.cor...b04ca08e3e.jpg https://cimg8.ibsrv.net/gimg/www.cor...1f5048fa6f.jpg |
:cheers:
Oh man, that is sweet. Now to figure out how to change grills without my wife finding out....
Originally Posted by meyerweb
(Post 1590523105)
Originally Posted by RPIDON
(Post 1590562044)
You can treat yourself to the grille and buy something for the wife? It a win win situation and everyone is happy :thumbs:
(Post 1590564778)
Don't know if that will work, but I ordered the grill a couple of days ago. With a little luck, she'll never notice. :D
(Post 1591053326)
:woohoo: |
Originally Posted by RPI Designs
(Post 1591059566)
Awesome picture! Glad you like the grill!
:woohoo: |
I have to run a front plate . will my GM aero plate holder work on this ?
thanks |
Originally Posted by zet06
(Post 1591066455)
thanks |
:thumbs:
Do you all plan on making these grills for the 2016+, which have the two cameras?
Thanks. |
Originally Posted by RACE U
(Post 1592186728)
Thanks. |
:thumbs:
Use coupon code LANA5 to receive 5% off your order!
Thank you for the orders! Use coupon code LANA5 to save 5% off your order!
Thanks for Checking us Out!! Use Coupon Code RPICHRIS5 for Immediate Savings!!!
OEM Z06 grille
(Post 1597892033)
Do you know if this grille is same material as OEM ? And do you know if i can slightly change shape by applying heat to it ? Putting on an aftermarket front and need to "bend" it slightly 3/4 inch center TIA https://cimg5.ibsrv.net/gimg/www.cor...98a4d0cb00.jpg |
Originally Posted by Z06Norway
(Post 1598942743)
Completely different Q.
Do you know if this grille is same material as OEM ? And do you know if i can slightly change shape by applying heat to it ? Putting on an aftermarket front and need to "bend" it slightly 3/4 inch center TIA https://cimg5.ibsrv.net/gimg/www.cor...98a4d0cb00.jpg Yes, this grille is the same as the original. As far as the heat goes, I really couldn't say for sure because I haven't tried it. It is plastic though so I would think it could bend some if you take time and are careful. Let me know if you have any other questions. Thanks, Chris |
