Originally Posted by Bad Bird
(Post 1590284968)
I run 34 psi all around on my 235/60R15 BFGs. Wear patterns look good, and the ride feels good to me.
Is that 34 psi COLD or HOT? If its COLD the "wear pattern" (whatever that means) may look even now but down the road you'll start finding the tread depth in the center is a lot less than the tread depth on the sides. |
33 to35 all around.
4 years later and 4000 miles not a hint of wear. This car is a pleasure car. It's not a pleasure to my wife to hear I need new tires. I think the ride is a little hard but cornering and off ramps at 40 mph blows back what little hair I have left. Marshal |
Originally Posted by 3JsVette
(Post 1590273407)
:yesnod: me too.
69 small block, just removed 265x50/15 tires that were 12 years old running 30 psi cold. No measurable difference in tread wear across any of the tires.
You have been working on cars for 60 years and have no idea what a "wear pattern" is? And here you are telling people to run their tires dangerously underinflated? Because you, and obviously NO ONE ELSE here has a tire wear problem and your cure was to let the air out?
Originally Posted by tracdogg2
(Post 1590288131)
Originally Posted by jb78L-82
(Post 1590271624)
I would not run less than 30 PSI on any tire on any car. For the max tire life and best fuel mileage as well as tire integrity a Michelin engineer told me years ago that you should run the most pressure (without exceeding the tires max pressure) you can tolerate ride wise and that also will allow even tire wear across the contact patch. Back in the 90's, I did just such a technique with a Goodyear Eagle GT+4 ZR tire running about 40-44 PSI and the tire lasted 50,000 miles which was unheard of back then for a Z rated tire. The goodyear shop could not believe it when I took them off the car.
I ran around 28psi cold in my PS2's from new and they lasted around 40k miles. The old owner ran 32psi cold in the PS's I took off and they were worn out in the center. That doesn't match with what Michelin told you would happen? I can't see any reason to run 20psi cold in any car tire though.... :leaving: |
Originally Posted by toobroketoretire
(Post 1590284986)
(Post 1590279822)
As 900 pounds is only half of the rated maximum load of 1885 pounds only half the pressure is required which translates to about 17 psi when checked COLD.
Professor, I'm sorry, but your logic is gonna get somebody killed. |
Tire patch is simple. Drive over some card board, and look at the pattern. Adjust accordingly within reason.
Running 225/15 with 32 psi. long life and good ride.
Originally Posted by Big2Bird
(Post 1590291292)
...Professor, I'm sorry, but your logic is gonna get somebody killed.
Seems we/re being forced to weather a barrage of such misinformation lately, which I do hope viewers who may be relying on the CF for genuine expertise are able to discern out. |
(Post 1590279822)
Originally Posted by lionelhutz
(Post 1590290872)
I can't see any reason to run 20psi cold in any car tire though.... :leaving: One key factor that I have not mentioned when running higher than "normal" pressures that is critical to maintain relative wear across the contact patch is you MUST rotate the tires more often a normal person would (which for most people is NEVER) if the tire is not uni-directional (which is not possible for uni directional tires...Only front to back, not side to side). Most tire techs will tell you that under normal pressure that they rotate their tires every 5,000 miles for max even wear. If I can rotate tires on my cars, I generally do it every 8-10,000 miles. |
(Post 1590292544)
Comparing a PS2 Michelin with 28 PSI versus 40 PSI on the same car, driven the same way, is the only true comparator for mileage wear.
I've seen complaints in the C5 forums about PS2's wearing out in the center first when using the recommended pressure on the car's label. I've also seen posts claiming Michelin says to run higher pressures. But I'll keep with the slightly lower pressure since I got around 40k miles on a tire that is only treadwear warrantied for 10k miles. |
(Post 1590292398)
Got any proof of this claim that pressure ratios with load from a reputable source such as a tire manufacturer?
The tire manufacturers only make the tires and the amount of pressure needed is dependent on what kind of load the tire is carrying. If you put it on a wheelbarrow 5 psi would be more than enough. Right after I bought my '82 in 1988 I noticed my tires would wear the centers out very quickly when 30 psi (COLD) was used. I dropped the pressures on my new tires down to 25 psi (COLD) and that helped but the centers still wore out. On the next set of tires I tried 20 psi (COLD) and they wore perfectly even so I have stuck with 20 psi (COLD) ever since. Remember, when a tire is run at freeway speeds the pressure increases 4-5 psi so on a freeway my tires will actually have around 25 psi of pressure which is more than enough for the small load they are carrying. |
I don't think 5 psi in a wheelbarrow is enough, even at sustained highway speeds. But next time I decide to drive my wheelbarrow down the interstate I'll check it out.
(Post 1590294009)
I see that I am not the only one:lol: |
I never add or subtract air from my tires. I'm a purist and I don't want to mess up the date code on my 1975 air. No, Really-----I take my age and divide it by two and then deduct 1.5 pounds. No, wait----I run 32 all around (except the spare which is usually flat if I need it).
Sorry I'm such a wiseass! |
Whatever you say.... But 255 series tires wearing the centers out unless you run 20psi? That is some serious hogwash. I'm running 30psi cold in a 275 series tire and 28psi cold in a 305 series tire and they are not wearing in the center, AT ALL, NOT ONE BIT. My car should be lighter than yours too.
