C2 scissor Jack--Think its a 1966 , maybe
How can I tell if its original not a repro . Thanks
This is from the 66 judging guide....
Check for the letter "A" stamped on the top lift pad... Dating/dates on the jack didn't start until Jan 67.... The jack has a washer sandwiched between two large flat washers...it is shorter than previous ones because of the nut end being turned inward...the jacking screw nut is 3/4 inch hex... Hope this helps...:cheers: |
I'll check it in the morning . Thank you
C 2 jack
Jack has letter A stamped on pad. No date located on the jack anywhere. The 3/4 nut has a bearing under it , no washers :-( what do I have ? Is it a repro ??
