-   C7 Vendor for Sale (https://www.corvetteforum.com/forums/c7-vendor-for-sale-163/)
-   -   SCP is your source for Corsa Performance Exhaust – Best Selection and Prices! (https://www.corvetteforum.com/forums/c7-vendor-for-sale/3707287-scp-is-your-source-for-corsa-performance-exhaust-o-best-selection-and-prices.html)
southerncarparts 09-03-2015 04:42 PM
C7 Corvette Corsa Exhaust Systems from Southern Car Parts!
We have many options to choose from allowing you to pick your ideal sound and style!
CORSA's new Corvette C7 exhaust systems from Southern Car Parts fit both NPP and Non-NPP-equipped cars. With straight through designs in two sound levels to choose from as well as a total of four different tip styles, we are sure there is a drone-free aggressive-sounding Corsa exhaust that’s perfect for you.
http://www.southerncarparts.com/imag...Zcd7F4Nck.webp
Here’s some info on the types of sounds you can get from these Corsa systems:
CORSA RSC™ SPORT exhaust system is Corsa's Mid-Level Sounding exhaust and is best described as producing a bolder sound most evident between 3000 – 5000 RPM WOT. Corsa Sport Exhausts are characterized by High performance sound a distinct rumble at idle and aggressive sound through the gears but still no drone during cruising.
CORSA RSC™ XTREME systems are Corsa's newest systems which are the loudest most aggressive systems Corsa offers. XTREME systems feature a deep growl at idle, bold during acceleration, and screams at high RPMs and still no drone at Cruise.
As for the tips, options include Quad 4.5” Round Pro-Series tips and Corsa’s special Polygon "Tail Light" Poly-style tips. Both are available in Polished Stainless or Black Stealth finishes.
https://www.southerncarparts.com/ima...0%2014764b.jpg
https://www.southerncarparts.com/ima...%20Xtremeb.jpg
https://www.southerncarparts.com/ima...e%2014763a.jpg
https://www.southerncarparts.com/ima...k%2014763b.jpg
https://www.southerncarparts.com/ima...0%2014764a.jpg
https://www.southerncarparts.com/ima...ack%20Tipa.jpg
https://www.southerncarparts.com/ima...e%2014763c.jpg
https://www.southerncarparts.com/ima...k%2014763a.jpg
CORSA straight-through design coupled with RSC™ noise cancellation technology allows us to tune out the undesirable low frequencies that cause droning, while reducing back pressure. A reduction in back pressure allows the engine to produce more horsepower and torque.
CORSA uses its patented Reflective Sound Cancellation™ (RSC™) technology to eliminate low frequency resonance while minimizing backpressure. Sound waves are reflected within the muffler case, producing a cancellation wave effect, with no flow restriction and without electronic devices.
Corsa Exhausts Feature:
- No Resonance / Drone - due to noise cancellation technology – RSC is whisper quiet at highway speeds
- Great Performance Sound - we tune in the good sounds and cancel the bad without the use of baffles or wool packing material
- Increased Horsepower & Torque - due to straight-through design = increased flow and less backpressure
- There is no drone with the CORSA exhaust system because the CORSA exhaust system uses RSC technology to eliminate problem frequencies that cause interior drone/resonance at cruising speeds. CORSA's Chevrolet Corvette exhaust system features a patented non-restrictive Straight-through design reduces back pressure and frees up additional power resulting in improved horsepower and torque. As an additional bonus, your Chevrolet Corvette can result in greater fuel economy because of less back pressure and more power.
Corsa Exhausts feature 304 Stainless construction throughout and are made in the USA. Corsa dB Series exhausts are their lower cost alternatives for trucks that feature mixed materials for construction and single wall tips depending on application.
NOTE: An additional $50 Rebate is available on select exhaust systems, please inquire at time of purchase.
Order here:
C7 Corvette Corsa Sport Valve-Back Exhaust System w/ Polished Quad Round Tips 14764
C7 Corvette Corsa Sport Valve-Back Exhaust System w/ Black Quad Round Tips 14764BLK
C7 Corvette Corsa Sport Valve-Back Exhaust System w/ Polished Poly Tips 14765
C7 Corvette Corsa Sport Valve-Back Exhaust System w/ Black Poly Tips 14765BLK
C7 Corvette Corsa XTREME Valve-Back Exhaust System w/ Polished Quad Round Tips 14762
C7 Corvette Corsa XTREME Valve-Back Exhaust System w/ Black Quad Round Tips 14762BLK
C7 Corvette Corsa XTREME Valve-Back Exhaust System w/ Polished Poly Tips 14763
C7 Corvette Corsa XTREME Valve-Back Exhaust System w/ Black Poly Tips 14763BLK
C7 Z06 Corvette Corsa XTREME Axle-Back Exhaust System w/ Polished Quad Round Tips 14766
C7 Z06 Corvette Corsa XTREME Axle-Back Exhaust System w/ Black Quad Round Tips 14766BLK
southerncarparts 04-07-2016 09:07 AM
Thanks for considering Southern Car Parts!
Dpriceslc 04-27-2016 04:21 PM
2014 Corvette C7 Sport Exhaust
2014 Corvette C7 XTREME Exhaust
Order here:
Is the additional $50 rebate still available?
southerncarparts 05-11-2016 04:45 PM
No, sorry, that offer from Corsa has expired.
southerncarparts 03-10-2019 11:03 AM
Order here:
southerncarparts 12-03-2019 12:21 PM
:cheers:
southerncarparts 11-10-2020 08:27 AM
Order yours today!
