Willcox Weekend Sale Special Discounts on Cooling, Weatherstrip, Wiring, Interior
New items added this weekend!
Cooling and Front and Rear Stock Suspension! Looking for a radiator, radiator support or Stock front or rear suspension.... We got you covered this weekend. Announcing our new VIP Program! Tired of discount codes, if so then this may be the program for you. Special offers and fixed discount codes when you apply. C1-C4 Don't forget to check out our clearance items out. Willcox Clearance Website. Or Willcox Clearance Ebay Repair and Installation Help Site: We've been working on sorting all the info for you by making categories for each page or manual on this site. http://repairs.willcoxcorvette.com/ Special Bonus!!! Back for One More Week: 1961-1982 owners that place any order over $100.00 can request a complimentary copy of 1 assembly manual. Simply place a comment in the notes section of your order specifying the year you would like. Weekend Sale Starts Now: This offer expires Sunday at Midnight The 15 off code is for most the entire website...So don't miss out! ! ! Ca map products are exempt.. that's about it. NEW15 is the code. Other exclusions are listed below. The 20 off code changes weekly so you'll have to check the flier below for details.... and CA products are exempt from this code as well. You should use the provided links at the bottom to maximize your savings. The codes have some restrictions (listed on the code flier) and special links are posted below to get you to the correct area needed for the appropriate discount. https://pbs.twimg.com/media/CQuSU2UVEAEkvx4.png To Receive the special discount you must order from the links below. You can place multiple orders and should if you need seat foam and other interior products. Review the items in the 20 code, they change weekly. Discounted Corvette Parts are only one click away! Seat covers. Discounted 58-82 covers can be purchased at the links below. Corvette Leather Seat Covers Corvette Leather Like Seat Covers Corvette Mounted Seat Covers Corvette Vinyl Seat Covers Original If you need seat foam, it is only eligible for 10 percent off and it would ship separately so please place a second order for the seat foam at this link. Discounted Corvette Seat foam Corvette Door Panels Can be found at this link! Select the year when you get to the page. Specify year and color when you check out. Corvette Dash pads Can be found at this link! Select the year when you get to the page. Specify year and color when you check out. Other items can be found here: Corvette Carpet Set * products are not those of CA https://pbs.twimg.com/media/CPCU8DbUAAAhOXv.png:large |
ttt
Email Sales@Willcoxcorvette.com for information on our New VIP Program!
ttt
ttt
Don't forget to visit the Repair and Installation Help Page at Repairs.willcoxcorvette.com
ttt
Ttt
Ttt
ttt
Ttt
I have a question, since you guys have been so helpful:
I am putting my car back together after numerous fixes, the most notable being you guys helping me with the blower motor. One of the things I did to fix it, was replace a blown fuse in the fuse block. While doing so, I noticed it was hanging by the wires that connect to the fuses, and was not screwed into the firewall as shown in the AIM. A closer inspection revealed that the plastic of the fuse block itself was broken, so that it could not be screwed in as designed. Can I buy a new fuse block? I couldn't find it on your site. Thanks, PK |
PK-
Fuse blocks are not available new from either harness manufacturer and I checked, I don't have a good used one either. I'm afraid you'll either have to repair the holes or purchase a new dash main. Plastic Fusion or Plastic Weld (same stuff under two different names) should be able to fix you up. I'd fill scuff out the the broken out area, fill the hole with this stuff allow it to dry, sand, drill and then re-mount it to the firewall. I don't know if there would be room to put a metal washer inside the fusion but I would possibly consider this as a way to make it stronger. Plastic Fusion is some pretty awesome stuff. -Willcox |
Originally Posted by Willcox Corvette
(Post 1590677593)
PK-
Fuse blocks are not available new from either harness manufacturer and I checked, I don't have a good used one either. I'm afraid you'll either have to repair the holes or purchase a new dash main. Plastic Fusion or Plastic Weld (same stuff under two different names) should be able to fix you up. I'd fill scuff out the the broken out area, fill the hole with this stuff allow it to dry, sand, drill and then re-mount it to the firewall. I don't know if there would be room to put a metal washer inside the fusion but I would possibly consider this as a way to make it stronger. Plastic Fusion is some pretty awesome stuff. -Willcox I don't think that is going to work because of the way it is broken. Let me try to get a decent picture, and maybe the crowd can give me some ideas of a work around. Thanks, PK |
get a pic and email it to me.. Support@Willcoxcorvette.com I'll double check to see if I have something.
