Benefit of Z51 sway bars on Non-Z51 C7 Stingray?
I am thinking of adding the z51 sway bars, front and back to my base Stingray 2015. Would this make the car handle better for some hpde fun / beginner. Anybody done this? Is it a waste of time with stock suspension? Ger. :blueangel:
Originally Posted by mungodrums
(Post 1590650973)
Gordy |
(Post 1590650973)
(Post 1590650973)
https://www.corvetteforum.com/forums...rformance.html |
We have these available for you!!
2014-2016 Corvette C7 Z51 Sway Bar Add On Upgrade Kit However, our prices seem to vary from other kits I have seen out there. This is a complete kit, where as other kits may not include everything you want, but only enough to get you by to install the upgrade. these are the part numbers and quantities for the kit. ask around and see what others are including. GM# 22936510, 20966781, 23305975*2, 20959449*2, 22945601*2, 23305978*2, 20959448*2, 11546672*4, 11588472*4, 11516078*8 |
There are two Z51 sway bar setups out there. The one for the non-mag shock car really does not make a very substantial difference. The mag Z51 setup that has the same front bar but, a much larger rear bar is the one to have for any kind of twisty fun. You WILL feel the difference with that kit and the costs should be about the same.
Originally Posted by firemangordy
(Post 1590651094)
I added them to mine and am very glad I did.
Gordy |
Originally Posted by axr6
(Post 1590657532)
I installed Z51 shocks and sways, and the handling is MUCH improved. But, now you have me wondering which rear sway I have.. |
Magride is 22936510.
Originally Posted by FYREANT
(Post 1590664886)
what's the part number for the rear sway bar of the Mag ride Z51? and what about the non mag ride Z51?
Originally Posted by subchev
(Post 1590654321)
these are the part numbers and quantities for the kit. ask around and see what others are including. GM# 22936510, 20966781, 23305975*2, 20959449*2, 22945601*2, 23305978*2, 20959448*2, 11546672*4, 11588472*4, 11516078*8 It looks like you're shipping a different pair of insulators, probably the ones that match the 22936510 bar. It also looks like you're supplying the same bolts for front and rear, where the "other" vendor is supplying different ones for each end. Finally, I can't find 11588472 at all. Lot's of people have successfully installed the Z51 bars using the other vendors kit. It would be helpful to know what the differences are with yours. |
To confuse it even further, there are two different bushings for the 31mm bar, one for the Z06 and one for the Z51 magride. I have the Z51 bushing for magride and the they are black rubber. I was curious what the other bushings looked like.
Originally Posted by meyerweb
(Post 1590668373)
Can you list the description of each of those parts? In particular, I'm interested in what part # 22936510 is. 22936508 seems to be what's included in other kits, and is listed as part of the FE3 suspension. IS the "10" bar from the mag ride suspension? Is that the FE4?.
Originally Posted by juanvaldez
(Post 1590665470)
(Post 1590668373)
It looks like you're shipping a different pair of insulators, probably the ones that match the 22936510 bar. It also looks like you're supplying the same bolts for front and rear, where the "other" vendor is supplying different ones for each end. Finally, I can't find 11588472 at all. Lot's of people have successfully installed the Z51 bars using the other vendors kit. It would be helpful to know what the differences are with yours. "In particular, I'm interested in what part # 22936510 is. 22936508 seems to be what's included in other kits, and is listed as part of the FE3 suspension. IS the "10" bar from the mag ride suspension? Is that the FE4?" 2014-2016 Corvette C7 Z51 Sway Bar Add On Upgrade Kit -GM#: 22936508 Rear Sway Bar (GREEN): SPORT SUSP(FE3) -GM#: 22936510 Rear Sway Bar (BLUE): SPECIAL SUSP(FE4),PERFORMANCE SUSP(FE6),HVY DUTY SUSP(FE7) "It looks like you're shipping a different pair of insulators, probably the ones that match the 22936510 bar. " -YES "Finally, I can't find 11588472 at all." -My sincere apologies, this was a typo: 11588742 is the correct number. 2014-2016 Corvette C7 Z51 Sway Bar Add On Upgrade Kit Over the weekend, I studied the Corvettes a little bit and wondered why the kit I had come up with was different as well. I had originally assumed that all of the C7 Corvettes were equipped with a front and rear sway bar; even if that sway bar might be quite small. With this in mind, I put together a kit for a full kit of front and rear z51 sway bar upgrades including four end links & nuts, insulators, clamps & bolts - front & rear, and both performance/heavy duty susp sway bars (FE6,FE7) Now I have revised my listing and will have prices posted on our site. <a href="http://www.trunkmonkeyparts.com/" target="_blank">Trunk Monkey Parts | Your source for OEM and Aftermarket Accessories. 2014-2016 Corvette C7 Z51 Sway Bar Add On Upgrade Kit A C7 Corvette Z51 sway bar upgrade kit includes: (1) 20966781 FRONT STABILIZER SHAFT (YELLOW)(CODE AAB5)(FE6,FE7) (2) 22950841 INSULATOR (YELLOW)(FE6) (4) 11546672 BOLT (2) 11516078 NUT (1) 22936510 REAR STABILIZER SHAFT (BLUE)(FE6,FE7) (2) 22945601 END LINK (FE6,FE7) (2) 22950837 INSULATOR (BLUE)(FE7) (2) 20959449 CLAMP (4) 11588742 BOLT (4) 11516078 NUT I hope this helps clear up all the confusion!! |
Thanks. Can you provide a link to the specific page on your site? The only listing I can find there still says call for price, and I think has the old parts list.
(Post 1590678779)
2014-2016 Corvette C7 Z51 (FE3) or (FE6,FE7) Sway Bar Add On Upgrade Kit :rock: <a href="http://www.trunkmonkeyparts.com/" target="_blank">Trunk Monkey Parts | Your source for OEM and Aftermarket Accessories |
Originally Posted by Walt White Coupe
(Post 1590659872)
Me too. :iagree:
I bought the kit that Cultrag Performance was selling:
c7-z51-bars 2014-2016 C7 Corvette Z51 Sway Bar Add On Kit $303.99 http://www.cultragfactoryparts.com/c...kit/c7z51bars/ These are the bars for a Z51. My car was a base car with the standard 18/19 wheels and no Mag ride . So I added 19/20 wheels with the lower profile all season Michelin non-runflat tires and the Z51 sway bars. I think it still rides smoother than my C6 did with the Z51 option which I thought was smooth enough so I like this setup. https://cimg6.ibsrv.net/gimg/www.cor...15fa7d4774.jpg |
I had been hearing the shocks on the Z51 are A little stiff.Sounds good for the track.But maybe if touring maybe the ones that come on the base give A smoother ride.
We are a newer Vendor on the forum, still getting the name out there..
We're offering these kits for a better price than a lot of competitors out there, and if you are not yet satisfied, then gives us a call and we will do what we can for you! 2014-2016 Corvette C7 Z51 Sway Bar Add On Upgrade Kit |
