Spec sheet for our M7 transmission (TREMEC TR-6070)
Originally Posted by Kracka
(Post 1590693958)
Any updates on fluid specs since 2015? How is the car shifting with the Redline D4 fluid you used when you changed the Trans and Diff fluid a while back? Any issues since then with the Trans or Diff? Are you still using Redline D4 fluid? Are you still liking it? Is it still the correct spec for our M7 trans? Have you found any better fluid you like better? Thanks, HPJ . |
I am still using the Redline D4 ATF and am on my 2nd fill of it with the car now at 37k miles. Shift quality remains superior to how the car rolled off the dealer's lot when it was brand new! This remains the correct spec fluid for our M7 transmissions.
Interesting - Tremec says the Z06 ratios, which presumably are in the ZR1 is only rated to 635 ft-lbs of torque.
(Post 1590693958)
stupid question. the damn spec sheet even says "ATF" am i to assume thats not a typo? im wanting to change the trans fluid in my car, with a whole 2500 miles on it, but.. yeah. strangely, the first few pages of search results = a bit dry. |
(Post 1595980285)
(Post 1595980285)
Mine is VERY notchy I would like to get rid of that. https://www.redlineoil.com/d4-atf |
Originally Posted by phalse
(Post 1598948446)
....aaaaand back from the dead bump;
Originally Posted by LIStingray
(Post 1595980337)
Originally Posted by GARYFINN
(Post 1598948714)
I'm not doubting your word however Redline says on their website that it is NOT recommended for a Corvette.What Say You ????
Mine is VERY notchy I would like to get rid of that. https://www.redlineoil.com/d4-atf MY VEHICLE 2016 CHEVROLET CORVETTE STINGRAYThis product is recommended for your vehicle. |
(Post 1595980337)
Redline D4 ATF fluid is the proper transmission fluid for all C7 M7 manual transmissions. 44k miles and on my 3rd fill of it now.
Originally Posted by 427C62013A
(Post 1599569231)
From this very web site it says it IS recommended for an M7 transmission.
MY VEHICLE 2016 CHEVROLET CORVETTE STINGRAYThis product is recommended for your vehicle. Same here for 2016 Z06 M7 |
