using a battery tender with the hood closed
Just wondering if anyone ever had a problem with vapors leaving a battery when a tender is on a car with the hood closed and a car cover on? Just a thought as i have usually left my hood open when on the tender over the summer months but would like to cover it this winter. I know i have noticed a lot of vapors when using a battery charger in the past but perhaps the tender chg rate is too low to have the same effect. I normally disconnect my batterys on my older cars but understand that is not advisable on the C6's. The car sits in a heated garage for at least 5 months over the winter. Sorry for the long winded post :D
Originally Posted by vt65
(Post 1590711978)
Also, I have seen people use those cigarette lighter hookups to charge the battery on the car, so I would imagine that would be fine as well. |
I leave mine with hood propped (to route cable out) and cover on. Never had an issue.
I keep my hood closed with a car cover on the car all the time. Mine stays under a carport but I've never had a problem with any kind of vapors.
Mine sits with the hood closed and cover on all winter, no problems ever.
I use the cigarette lighter adapter with the hood and door closed. BTW, there is no problem disconnecting the battery for a few months. C6 is no different than any other car with the battery disconnected.
Might be a good idea to leave the hood open a bit if you connect it directly to the battery. You're not as likely to drive off with it hooked up that way. :)
Have always left the hood cracked open and never use a cover when the battery tender is hooked up.
thanks for the replies, looks like i'll give it a try, maybe lay a light cloth over the battery and clamps just in case
C6 is no different than any other car with the battery disconnected. E V Rose. thought i read that the computer loses it's setting and the side windows need resetting etc., just want to avoid any hassles |
(Post 1590713051)
I have the battery tender hooked up, hood closed and car covered all winter in the garage and have never had a problem or smelled any vapors. I also made a small sign saying "Battery Tender" which I leave on the steering wheel for those rare winter days when I can (and do) drive the Corvette.
:cheers: |
Use my battery tender ever since new, in 2009. Always connected when the car is not in use through an external connection at the front grill. Always with the hood closed, and most often under a car cover. Closed hood and covered car not a problem with a tender, but if using a battery charger, then venting is probably recommended.
https://cimg4.ibsrv.net/gimg/www.cor...1a4988cddb.jpg The tender connected to the grill mounted connection. |
The hood is not anywhere near air tight...its' position will have no effect on the battery or the tender.:thumbs:
I leave mine cracked a little under my cover,just lower hood on an old sweatshirt. ..http://i67.photobucket.com/albums/h3...psv4ds6ici.jpg
http://i67.photobucket.com/albums/h3...pss3yzsjwh.jpg http://i67.photobucket.com/albums/h3...ps6ze3wzqv.jpg http://i67.photobucket.com/albums/h3...psgwfjnby9.jpg |
I'm in with the cigarette lighter, across the seat and out the drivers door with the cable in the divit in the sill {almost like it was put there} and shut the door.
Originally Posted by psp6158
(Post 1590714272)
Originally Posted by rado63
(Post 1590713998)
Originally Posted by Don-Vette
(Post 1590714254)
http://i67.photobucket.com/albums/h3...pss3yzsjwh.jpg http://i67.photobucket.com/albums/h3...ps6ze3wzqv.jpg http://i67.photobucket.com/albums/h3...psgwfjnby9.jpg I do have the cigarette lighter set up for CTEK and have used it but I prefer the direct connection to battery. I have had no problems with battery vapor. In fact my original battery is over 10 years old now and I started using a battery tender in about the 3rd or 4th year of ownership of Corvette that I ordered from factory. That's a good idea on using a microfiber in between the hood and cord. I will have to try that but have had no problems so far. The only thing I do notice is that sometimes the CTEK battery tender gets hot. |
Originally Posted by LS WON
(Post 1590716420)
fyi: I saw a newer version of this brand of battery tender at Costco for $39.95.
I use the magnetic connection in the front grill, not connected directly to the battery either, connected to the fuse box and the ground. Leave mine connected all the time with hood closed for years. Plus with the magnetic connection you just back out and it disconnects
