Wheels "ticking" during turns-fixed
I'm not sure if anyone has experienced this but I had an annoying ticking noise when I turned the wheel on my Z07.
The dealer cleaned the back of the wheels and re-torqued them. This fixed the problem. Apparently a lot of people are experiencing this. Just thought I would share |
Yup, that solved my problem as well
:rock: |
For a couple of weeks and it will be back.
It is a Chevy, what do we expect after all?
Originally Posted by jaden61
(Post 1590732491)
So just clean the back of the wheel where it meets the hub and that's it? Any type of cleaning solution that needs to be used?
Originally Posted by Toilets
(Post 1590732623)
They have powdercoated the front hub. You have to clean paint off of mounting suface. The rear hubs are bare metal. Solved my issue.
HA! I got tons of ticking after putting on the Cup wheels and ZR1 pads. I thought it was something I did. Some of you are getting this with entirely stock setup?
They will clean the hub too. Soap and water or wire brush? IDK.
1 Attachment(s)
Originally Posted by SBC_and_a_stick
(Post 1590732768)
they did this on mine. fixed it temporarily.
I took and replaced my wheels with powder coated ZR1 cups and no issue.
13,200 miles. |
Zero "ticking" after the dealer cleaned my hubs. Only other maintenance I've done to help this issue is re-torque the lug nuts after race events or some heavy spirited driving.
YMMV :cheers: |
Interesting...I did notice this ticking with the stock wheels on my Z07. Never thought much about it, but it has not happened since I switched to my forgelines.
Mine did it, they cleaned the wheels and put them back on, its already doing it again.
They had this problem on the Gen 2 CTSv's. Several tech bulletins were issued.
1) the first one (2010-2011?) was to remove wheels, clean mating surfaces, and retorque the wheels (maybe to 160 foot pounds?). Seemed a temporary fix for me. 2) Next bulletin was to replace the front wheels with "modified" wheels that had slits machined into the mating surfaces. Also a temporary fix for me, but clicking was milder when it returned. 3) the last and final bulletin that I knew of was to replace the lug nuts with a new part number. This worked for me (didn't really care at that point; it was not a big deal), but I sold the car within 5K miles or so of having it done. Haven't noticed it yet in the Z06 but I won't let it drive me nuts when I do notice it...... |
This is why they should be Hub Centric wheels, not lug centric... I have aftermarket wheels that are hub centric and I do not have this issue. So here is a thought, we need to measure the hub on the factory wheel then the actual hub, should be able to purchase hub rings often used on aftermarket wheels and I bet this will resolve the issue... Should be a cheap fix as well. Bet your car will drive smoother on the road as well, mine did after swapping to aftermarket wheels!
On the to do list for the dealer. Will report back soon.
Can anyone pull up that service bulletin number or info?
I have the issue as well. Z07 with 15k+ miles. I usually only hear it in the parking garage. Thanks! Best, Gene :cheers: |
