Manual Hood Light Switch
Has anyone taken the time to install a manual hood light switch. Would you bother again and how did you complete the install.?
Thank you for you input. Be safe, go fast. :D |
Most of the Corvette accessory catalogs have harnesses for the underhood lights that use a manual switch. It's a true plug-n-play setup. Try Mid America for a harness.
Originally Posted by c4cruiser
(Post 1590752937)
Originally Posted by steve1657
(Post 1590752955)
Nice, thank you. :cheers:
I'm happy to answer any questions you may have! :cheers: -Nick |
Originally Posted by Mid America Motorworks
(Post 1590755325)
It's in stock and ready to ship out, it can ship same day depending on what time you order it if you decide to go through with it. :thumbs:
I removed the entire wire set up. Those two lights are nothing against a LED flashlight.
Originally Posted by PLRX
(Post 1590755503)
Now I have to thinking to do... :toetap: |
I put in the Mid America light switch kit years ago. Easy installation and everything needed to do the job in one kit. The black wire loom that came with the kit matched all the other loomed wires I've done in the engine bay. You can just see the red tipped toggle switch under the light.
http://img.photobucket.com/albums/v7...odstrut001.jpg |
(Post 1590752738)
Thank you for you input. Be safe, go fast. :D :D |
Originally Posted by Black'95
(Post 1590757428)
I just pull the fuse located by the left front side marker light! You could just solder a switch to two fuse blades and insert that in place of the fuse or in series with the fuse.
:D |
Does anyone sell an led lamp conversion for the factor hood lights? I know you can change the bulb but wondering if someone makes a multi led light to replace them.
Originally Posted by crowz
(Post 1590757735)
:rock: |
Originally Posted by CREWZIN
(Post 1590757336)
http://img.photobucket.com/albums/v7...odstrut001.jpg my eyes must be bad because I dont see it. got any closer up pictures? |
I put a kit in last year similar to this one: http://www.ecklerscorvette.com/corve...late-1996.html
Plug and play and prevents a mechanic from leaving the hood up over the weekend and forgetting about it and running the battery down (DAMHIK and it wasn't me). Takes longer to run the wires than it takes to hook it up and simple pushbutton switch to turn them on and off with the hood up. |
(Post 1590757428)
I just pull the fuse located by the left front side marker light! ....
It is quick and easy. Maybe 10 seconds to unplug and remove the fuse. |
My car doesn't have a fuse. That must have been added in later years...
Originally Posted by chadk
(Post 1590758881)
http://img.photobucket.com/albums/v7...C00002%202.jpg |
This is an easy fix. About 15 years ago I cut the hot wire on each side going to the lights and installed a $3.00 toggle switch in each wire. The lights are always off. If I want them on I flip the switch. Never have had any problem with them.
