Can someone modify my tune to delete the rear o2 sensors ?
I have tested the diablo tune for my Z51 and I loved it.
I'm installing a set of LT headers and off road xpipe. Can someone modify my tune to delete the rear o2 sensors ? I don't want to change anything else, the car runs great, good mpg and it's my daily driver. I live in Europe, there are no Corvette tuners around here to do a custom tune... |
Get a HP tuners Suite and you can do that, and much more later if you decide.
Originally Posted by sycraft
(Post 1590988109)
Originally Posted by ElSpa
(Post 1590987903)
I'm installing a set of LT headers and off road xpipe. Can someone modify my tune to delete the rear o2 sensors ? I don't want to change anything else, the car runs great, good mpg and it's my daily driver. I live in Europe, there are no Corvette tuners around here to do a custom tune... http://www.diablewtune.com/ |
Originally Posted by xp800
(Post 1590988299)
Contact Diablew (Monte06SS). He can do a custom mail order tune through the Diablo for $150 for the added parts and cat delete.
http://www.diablewtune.com/ You will need the front o2 sensors turned off with headers and off-road X-pipe. The rear cats are not monitored on USDM cars, not sure about European-spec cars though. |
Originally Posted by Kracka
(Post 1590988456)
:iagree: Lew does great work and it couldn't be easier since you already have the Diablo.
You will need the front o2 sensors turned off with headers and off-road X-pipe. The rear cats are not monitored on USDM cars, not sure about European-spec cars though. You never turn off the front O2's. They supply the PCM necessary feedback on the A/F ratio. In HP Tuner, you actually stop the PCM from turning on the Check engine light or setting a code when the rear O2 sense the cats are not efficient enough. |
