Change stock headlight bulb?
I'm probably going to get flamed as usual, but was wondering if anyone has changed out their stock projection bulb and replaced with an HID or LED? I'm looking to get just a hint of blue.
thanks John |
Still getting my c7 vette later this week, but I am interested in the same thing. 6000k or 8000k would be a nice mod.
6 or 8 will look ricer, IMO.
You'll have to at least pull the front bumper. So if you have any plans for a new grill or some such thing... you might want to do all this in one shot.
You may also run into electrical issues depending upon current draw for these lights. Something tells me everything is very carefully computer controlled in C7's and it might throw some codes... check carfully with the vendor... ask to see a C7 with the lights.... who knows, once you see it, you may or may not like it... |
Originally Posted by AirStingray
(Post 1591025772)
Originally Posted by Glen e
(Post 1591025779)
A little neon under the wheel wells at the same time.
The "stock" bulbs are already HID:
Ref RPO TF4 - Headlamps, high intensity discharge (HID), Xenon, LED park and turn signals and Daytime Running Lamps |
I have a source for 6K bulbs for the C7. I've had mine in for close to a year and no issues.
Elmer |
For reference:
https://cimg5.ibsrv.net/gimg/www.cor...6ed31de420.png |
Not my cup of tea but to each their own. This is not going to be an easy or cheap project.
Originally Posted by Prodago
(Post 1591026361)
if your including Ferrari as ricer, then yep
6K is as high as I go on headlights. I don't want blue or purple! I want bright white!
Elmer |
Originally Posted by eboggs_jkvl
(Post 1591026620)
Elmer |
Originally Posted by MikeyTX
(Post 1591026656)
You just replaced the high beams didn't you ?
Well, technically I replaced both high and low as they are the same bulb. We have a shutter that blocks the light to make it low beam and then the shutter is moved out of the way and the full High beam light goes out. Elmer |
you guys did not disappoint!
I have HID kit in 02 dodge truck and I can see better at night, much cleaner look. I think its 6000. Don't get me wrong I'm not looking for the purple idiot look, sorry to my purple headlight idiots peeps, just seems like the lights could be more white, mine looks like it has a slight yellow tint, sort of like my truck had before HID. anyway to each their own. if it involves removing front nose then uh....yeah....that aint happening. I'll just install the gun rack! |
(Post 1591026361)
(Post 1591027048)
Originally Posted by meyerweb
(Post 1591027107)
You have any supporting evidence that Ferrari's come standard with 6,000K (or even worse, 8,000K) lamps?
Do you have to pull the whole assembly to swap the bulb? I haven't really looked at the light assembly.
Originally Posted by Rooster OG
(Post 1591032419)
Elmer |
