Xplosive Performance |
12-08-2015 08:45 AM |
aFe Power Magnum FORCE Stage-2 Intake Systems 15% Rebate
15% Rebate direct from the Manufacture
https://www.corvetteforum.com/forums...dfe08d-420.jpg
http://www.xplosiveperformance.com/a...S3_p_3980.html
+22 HP / +19 lbs. x ft. Torque max gains (vehicle tested with aftermarket exhaust)
• Outflows factory intake by 50%
• Vacuum Formed ABS Plastic Intake Cover
• CAD-Designed Roto-Molded Intake Tube
• Pro 5R pre-oiled, washable/reusable air filter for maximum performance
• No Cutting or Drilling on OEM Parts for Faster Installation
* *No Floating Tubes* - Built-in ram scoop forces cold air to filter for greater efficiency and performance gains.
* *Clamp Stops* - Raised stops on aFe tubes provide a more secure seal and eliminate slippage versus flat, straight tubes.
* *3-Angle Adapter* - Specially developed velocity stack with 3 different angles dramatically increase airflow from the filter to the intake tube.
* *Quality Hardware* - aFe uses only top-quality hardware like stainless steel button head bolts and brass inserts.
Go to the following link and fill out the form
http://afepower.com/rebate/
Then print the confirmation as your rebate coupon and mail it back to aFe Power, along with a copy of your sales receipt by 1/31/2016.
aFe Power
Attn: 2015 Holiday Rebate
252 Granite St
Corona, CA, 92879
