Could this transmission be installed in a C3?
1997-2004 CHEVY CORVETTE 6 SPEED MANUAL TRANSMISSION
http://www.ebay.com/itm/1997-2004-CH...-/272080260791 I know it wouldn't as it is now but can it be done? |
Originally Posted by ZAKsPop
(Post 1591149536)
http://www.ebay.com/itm/1997-2004-CH...-/272080260791 I know it wouldn't as it is now but can it be done? Good luck... GUSTO |
Major modifications,
T56 from a camaro goes in fairly easily - Good luck, Frank |
Originally Posted by myoriginal77
(Post 1591149745)
T56 from a camaro goes in fairly easily - Good luck, Frank I'm going to research the T56. |
I found this...
https://houston.craigslist.org/pts/5343954434.html Does it have to be from a Camaro? This is from a 2000 Trans Am. |
That would work.
I have 3.36 gears and it's fine. At 70 I turn 3K. Sure it would be nice to have one more gear, but I don't go over 70 often. |
(Post 1591149815)
I found this...
https://houston.craigslist.org/pts/5343954434.html Does it have to be from a Camaro? This is from a 2000 Trans Am. There are several different versions of the T56 including an LT SBC, and GTO. All are a little different and you need the right parts for each. I have a double overdrive TR6060, and it is great |
I have a t56 magnum in my C3 now with a tube chassis and C4 ZR1 suspension. It was a tight fit and to be honest, with the 603hp and 540lb/ft of torque I can't even use the 6th gear unless i'm doing over 80 mph and then I'm only at 1800rpm.
On the road race track on the main straight, I still only got up to 5th gear and that was at 125mph and still had more rpm to climb. |
(Post 1591149536)
http://www.ebay.com/itm/1997-2004-CH...-/272080260791 I know it wouldn't as it is now but can it be done? T56 for new gen cars or T56 magnum new units. Silver sport is now providing perfect fit kits with all the parts. My did my install from a number of vendors for parts. Here are my notes on the install in a 78 corvette. https://www.corvetteforum.com/forums...-corvette.html |
(Post 1591149536)
http://www.ebay.com/itm/1997-2004-CH...-/272080260791 I know it wouldn't as it is now but can it be done? No, but anything is possible with enough money. :cheers: |
Since the C5 and newer Transmissions really don't fit any muscle cars easily I'm under the impression that people are converting them for use in a conventional mounted trans. I'm not sure if the entire main case needs to be changed or just the ends. One way or another it would be a lot of work to build a usable trans.
(Post 1591149745)
