FS-'63-'67 parts
5 Attachment(s)
I have been cleaning out stuff from the garage. Some are general new reproduction parts and some are NOS parts and a couple used. I have included pics. All prices are $$ or BO and DO NOT include shipping. Payment via Check or Money Order, First come, first served!
"63-'64 blue dash insert w/4 holes…………$6.00 '63-'67 tinned copper oil line w/fitting…..$8.00 '63-'67 clutch linkage anti-rattle spring…$1.00 Manifold vacuum fitting…………………………$5.00 Clutch/brake pedal bushings………………….$1.00 MIA! Temperature sending wire cover…………..$1.00 '63-'67 locking gas cap with key……………$30.00 SOLD '63-'67 headlight adjusting plastic clips…$1.00 SOLD '63-'67 gauge cluster grounding clip…....$1.00 '63-'67 headlight bearings/pivot balls…….$10.00 SOLD '63-'67 BB rear sway bar brackets…………$25.00 NOS/GM brake hoses……………………………..$20.00 SOLD NOS/GM bellcrank pivot stud/ball………….$3.00 SOLD NOS/GM choke coil SB Holley………………..$30.00-SOLD '63-'67 LIC odometer & trip odometer…..$60.00 Manifold 1/2" hose fitting……………………….$2.00 HP by-pass hose fitting…………………………..$4.00-SOLD Moog front sway bar end links……………….$5.00 Replacement blue seat belts (pair)………..$50.00 SOLD Single black GM issue replacement seat belt dated '69…………………………………..$15.00 ARP header bolts, 12 point 3/8………………$8.00 NOS/GM visor vanity mirror…………………..$5.00-SOLD Original GM windshield washer bag for C-3 w/A/C SB NO leaks, 5 3/8" between holes….$50.00 SOLD Thanks for looking. :cheers: Dennis |
Originally Posted by Bluestripe67
(Post 1591169332)
I have been cleaning out stuff from the garage. Some are general new reproduction parts and some are NOS parts and a couple used. I have included pics. All prices are $$ or BO and DO NOT include shipping. First come, first served!
"63-'64 blue dash insert w/4 holes…………$10.00 '63-'67 tinned copper oil line w/fitting…..$15.00 '63-'67 clutch linkage anti-rattle spring…$2.00 Manifold vacuum fitting…………………………$7.00 Clutch/brake pedal bushings………………….$2.00 Temperature sending wire cover…………..$2.00 '63-'67 locking gas cap with key……………$30.00 '63-'67 headlight adjusting plastic clips…$2.00 '63-'67 gauge cluster grounding clip…....$1.00 '63-'67 headlight bearings/pivot balls…….$20.00 '63-'67 BB rear sway bar brackets…………$40.00 NOS/GM brake hoses……………………………..$20.00 NOS/GM bellcrank pivot stud/ball………….$4.00 NOS/GM choke coil SB Holley………………..$30.00 '63-'67 LIC odometer & trip odometer….. and speedometer center magnetic pole…$150.00 Manifold 1/2" hose fitting……………………….$3.00 HP by-pass hose fitting…………………………..$4.00 Moog front sway bar end links……………….$6.00 Replacement blue seat belts (pair)………..$50.00 Single black GM issue replacement seat belt dated '69…………………………………..$25.00 ARP header bolts, 12 point 3/8………………$10.00 NOS/GM visor vanity mirror…………………..$5.00 Original GM windshield washer bag for A/C SB/BB NO leaks, 5 3/8" between holes….$60.00 Thanks for looking. :cheers: Dennis Matt |
I will also take the brake hoses. Thank you. PM Sent.
PM sent, thx
PM sent on by pass hose fitting.
(Post 1591169332)
If original, I'll take it. |
Originally Posted by ifitgoesfast
(Post 1591172014)
Original or reproduction?
Dennis the NOS/GM visor vanity mirror does that have anything on the mirror it self?
Keith, In the upper left within a square outline it says GM. The Part #981825 is on the end of the box. :cheers: Dennis
Dennis the one I'm looking for says Chevorlet on the mirror But yours is cheap enough. Wonder I well that would handle in the mail
Keith, I can put it between two pieces of cardboard. Should be OK. Do you want it? :cheers: Dennis
Sure what do you want for payment. My zip code for shipping is 17331
Check your PM
Re-run of FS items.
Many items still available. Thanks, Dennis
Someone out there needs something from this list! :D
Parts re-run
Bringing back my list for a check-up!
Bell housing pivot ball
(Post 1596676168)
Please advise shipping on that item to 30813 Grovetown, Georgia. Thanks, Tugboat53 Bill in Georgia |
I will buy this.
63-'67 locking gas cap with key……………$30.00 Do you do PayPal? |
Originally Posted by 68hemi
(Post 1596678528)
I will buy this.
63-'67 locking gas cap with key……………$30.00 Do you do PayPal? Dennis |
Dennis, Sent you a PM on the w/w bag.
John |
