Changing the Z06 A8 trans fluid and filter.
Now that the manuals are out can anyone post the information. I maybe doing this over the winter. Thanks
Originally Posted by C7/Z06 Man
(Post 1591201862)
Since the change interval is so long on the A8, why do you feel the need to change it so quickly? Bish |
Originally Posted by thebishman
(Post 1591204755)
I believe that this is a 'semi-sealed' unit now, and it's relatively difficult to change the oil/filter.
Since the change interval is so long on the A8, why do you feel the need to change it so quickly? Bish Bill |
https://cimg3.ibsrv.net/gimg/www.cor...46d011f256.jpg
Leave the A8 alone. My friend's A8 is giving his trouble. The dealer contacted GM, and they told the dealer not to do anything to it. We will send a new A8 for you to install (warranty), you remove the old A8, and send it to us unopened. If you deviate from the owners manual it may ...it may void the warranty. This is newer technology. The ATF on the 4L60E (93-96 Vettes) was good for 100,000 miles, and they didn't have a cooler. Just the lines thru the radiator. |
(Post 1591201862)
I assume you are not tracking the car? If you do and somewhat regularly then the Corvette manual for "Severe" conditions recommends 45,000 mile change of the fluid/filter. Same for the differential fluid at 45k...(and many change the differential much sooner). |
Originally Posted by BOBSZ06
(Post 1591205411)
(Post 1591207328)
Yes, I take the car to the track. I would like the information in case I would want to change it.
Severe definition: https://cimg4.ibsrv.net/gimg/www.cor...f8354782a6.jpg Severe Schedule: https://cimg5.ibsrv.net/gimg/www.cor...4f03039038.jpg |
(Post 1591208319)
Severe definition:
https://cimg4.ibsrv.net/gimg/www.cor...f8354782a6.jpg Severe Schedule: https://cimg5.ibsrv.net/gimg/www.cor...4f03039038.jpg Thanks much for taking the time to post this information and I may not change the trans fluid for some time, but I still would like the manual's trans/filter change info if anyone has it. PS: I did change the differential fluid with what GM specs for the rear, approx. 3 quarts to fill which I did at 1,500 miles. Between what the old fluid looked like compared to the new and the amount of magnetic sludge on the magnet drain plug I'm glad I changed it. It maybe a good while before I think about changing the trans fluid but I would still like to know procedure, amount, etc. :cheers: |
(Post 1591208618)
It says change fluid and filter, where is the filter located if there is no pan to remove?
Bump
Originally Posted by DLC7
(Post 1591601527)
Bump
https://cimg2.ibsrv.net/gimg/www.cor...6708c0478a.jpg
The atf left in the pan was fine. Will probably hold off doing this again for a while. |
How did you get the fluid out of the converter where most of it resides?
Originally Posted by CONMAX
(Post 1591648454)
Originally Posted by rsalco
(Post 1591648589)
He didn't. Because you can't without a pump inline with the trans cooler. Or by dropping the trans and removing the torque converter.
Pan pic
JMHO, By looking at the fluid and the pan with the magnets from the pic everything looks "great" so no real need for a fluid change.
If the pan would of had darken discolored trans fluid and/or clutch materials in the bottom along with magnetic muck on the magnetics then a fluid change is in order. This pan was clean in my book so I most likely would have reinstalled the pan and replaced the fluid. One reason that I would consider doing this is I have read a few posts that pressure changing of fluid has caused some trans problems in the past which the trans did not have before the pressure fluid change. PS: The one good thing that I would of taken away from this experience is that the trans is still in good shape with little to no wear on the internals. :thumbs: |
(Post 1591649143)
(Post 1591657976)
Good info. Had I known the dealership did not have the proper tools, would have held off this. Now I have old ATF intermixed with 8Qts of new fluid. Not thrilled about this. Mostly b/c I burned the better part of one full day waiting for this to be done, but it was not done right.
I had an "A6" 2010 Grand Sport which "still" holds the stock GS 1/4 mile record on this forum this many years later. It started to shift funny sometimes during regular driving; harsher down shifts when coming to a stop. I change the trans fluid and filter by dropping just the pan which does not remove all the fluid in the trans or converter. THE RESULTS: The trans was right back to the day I bought the car (smooth as ice) and stayed that way for the rest of the time I had the car and I raced it much after the fluid & filter change. PS: However my pan and fluid was not clean at all, muck on the magnet and laying in the pan along with some discoloration of the trans fluid. :cheers: EDIT: After drying "everything" up well underneath "I" would give it a few days to a week but I would check to see that there are no leaks around the pan, etc. |
